Old 08-22-2016, 01:22 PM   #1
Moneymatt448
What proportining valve do I need for disc / drum on 69 Chevy
I have a 69 Chevy c10 that had drum / drum set up I switched it to 72 disc / drum set up but I need help picking the right proportining valve do I have to add extra break lines or can I just use the existing ones from the drum drum set up
Moneymatt448 is offline   Reply With Quote
Old 08-22-2016, 09:49 PM   #2
dennislbrooks
dennislbrooks's Avatar
Re: What proportining valve do I need for disc / drum on 69 Chevy
On my 67 I also went to 72 disc but I kept the original 67 front rear brake splitter and plummed in an adjustable proporting valve in the rear line that I could adjust from inside the cab. I also changed the master cylinder to an 82 vette - 72 c10 would be ok also. Speedway also says to run a residual valve on the rear brakes if drums , I did not. When I went to disc all the way around all I had to do was readjust my rear brake valve.
Be safe and test your brakes before venturing into normal traffic.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T
dennislbrooks is offline   Reply With Quote
Old 08-22-2016, 09:54 PM   #3
Moneymatt448
I bought a 73 booster master cylinder was going to just install that one and get a new proportioning valve .
Old 08-22-2016, 10:04 PM   #4
Moneymatt448
How did you plum it in
Old 08-23-2016, 10:54 AM   #5
dennislbrooks
It is a knob style adjustable proportioning valve. Like speedway part number 910-31353.
remove rear brake line from oem splitter valve. use splice if needed to run line to the out side of the knob valve. run a new short line from in side on knob valve back to oem splitter valve. mount under dash. will show a pics.
73 master cylinder should be ok.
Old 08-22-2016, 09:57 PM   #6
MikeB
MikeB's Avatar
I wouldn't add a valve unless the rear brakes lock up under heavy braking.
Mike
1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
69 c10, disc conversion, proportioning valve
