08-24-2016, 11:41 AM | #1 |
Frame strength help...
Hi,
Would a 1963 C20 frame be strong enough to handle a 4wd conversion (np205), Dana 60 front, 14 bolt rear, 6 lift and 37 tires? Thanks for the help!! |
08-24-2016, 05:19 PM | #2 |
Re: Frame strength help...
yup
2000 GMC CCSB 454/4L80 6 lift SAS 1999 Chevy CCSB 454/NV4500 6 lift 1999 GMC Yukon 350/4L60 4" SAS |
08-24-2016, 09:18 PM | #3 |
08-24-2016, 11:24 PM | #4 |
Bunch of hooey. If I understand correctly, there isn't much difference between the frame rails of 2wd and 4wd. Once you remove the front crossmember, I would really look into a crossmember to tie the frame back together under the engine mounts but that might be about it. My '63 has never had a crossmember in that area and although Ive always wanted to install a support there, Ive never really seen the need for it even with the new suspension, drivetrain and big block. Boxing the frame IMO, while cool looking and very labor intensive, is completely unnecessary in most cases.
Stock frame in mine has seen thousands of towing miles, many loads in the box that were well over the trucks capacity without any indication of fatigue. Im not sure why an honest restoration / body shop would recommend welding plate to the inside of the frame. Ive seen several instances where frames are not supposed to be welded on due to the alloy that they are made of. Not sure if our old truck frames would be affected. Just saying it would be good to research completely on your own before asking a barber if you need a hair cut.
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
08-24-2016, 11:27 PM | #5 |
I don't know much about this subject but the one thing that I do know is that you should at the very least reinforce the steering box area of the frame otherwise it will crack and rip out with those big tires up front.
08-24-2016, 11:48 PM | #6 |
After thinking about it a little more, for the cost of boxing a frame on one of these, Id bet that you could find an original 4x4 truck. They're not super common, but not extinct either. Just another angle to think about.
08-25-2016, 03:50 AM | #7 |
The k frames aren't significantly different than the c frames. Do you plan on rock crawling or speeding over whoops? Then you may want to reinforce any factory light duty Truck frame. Driving offroad trails, fore roads and around town? No reinforcement necessary. It also depends on other factors. Have nice flexible suspension? Less stress on the frame. Have super stiff aftermarket lift springs? More street on the frame.
What power plant do you intend to put into it? SMall block, big block, LS, 6bt?
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! |
08-27-2016, 12:23 AM | #8 | |
Probably a 350, not sure what tranny yet. No even sure if it will be manual or auto. The lift will be full spring with Bilstein B8 5160 shocks. No rock crawling or mud bogs for this build, but I will take it off road on trails, potential deep snow through pastures, some mud, definitely steep hills and lots of pavement. I have since spoken to a few people who suggest either boxing from transfer case forward and leaving the back alone, to just adding a crossmember or two. I have noticed online lots of people converting C10/20's to 4wd seem to prefer Suburban chassis swaps, but I hate the way it looks. I'm going for a factory look minus the lift.
1959 Power Wagon WM300 (future project truck) 1966 F250 Crew Cab 4x4 1963 C20 4x4 (current project) 1970 F250 Crew Cab 4x4 (ongoing project) 2012 F450 KR 4x4 6.7 2017 F350 KR 4x4 6.7 |
08-25-2016, 08:14 AM | #9 |
Has anyone compared frames from an early 60s to a modern frame? Granted braces, crossmembers, funky bends and what not, but these frames are thick. Back when they built trucks, I wouldn't hesitate running the frame as is. Now if you do plan on serious off-road, 800+ horses, towing doubles then maybe want to box the frame.
08-25-2016, 09:02 AM | #10 |
I have compaired my 63 K20 4x4 frame to my 93 dodge w350 and it is comparable.
Not enough difference to remember or worry about.
63 k20 with cummins 4bt, owned sence 1982 |
08-25-2016, 09:05 AM | #11 |
Welcome back there Jason. Didn't you have some plate cut up to box Big Ugly at one time?
08-25-2016, 10:10 AM | #12 |
It is hard to compare new and old frames. The metallurgy is different and most new truck frames have boxed sections. This gives them more stiffness in twisting and bending. Also they vary from generation to generation aND between capacity. The 73 k20 frame I robbed parts from was thicker and seemed harder to cut through than my 66 k10 frame. And the 83 k30 frame was thicker still.
08-25-2016, 10:13 AM | #13 |
Hey Chris. I did persue boxing my frame. But I abandoned it when I moved 4 years ago because I had to get the truck reassembled and had no space where I was moving to.
There are several things that I'd do differently if I had it to do over again. But i think it'll be a long time before I build another truck. Too many other things to do in life
08-27-2016, 12:58 AM | #14 |
A small block and mild offroad: I wouldn't worry about boxing the frame. Just make sure you have good crossmembers located at spring and shackle hanger locations. You should be good to go. 37" tires seem a bit big for your intended use, but should work.
08-27-2016, 11:37 AM | #15 |
I've got 35's on all my other trucks and have wanted to put 37's on something, so I thought this might look cool and different. All the '63 C10/20's I see are stock looking. Just want something a little different.
02-26-2023, 03:51 PM | #16 |
Dont know if this helps but 67-72 c20 frames are actually stronger then their k20 conunter parts. The gvw of a k20 is way less and also the fact I've looked into a k20 of this era is basically a k10 with stiffer springs and axel. Also some c20s came with Ho72 to handle the higher gvw. Know I dont know if there is any specific bracing that a 4x4 has but I would say a c20 will be fine. A c10 might be another issue.
02-27-2023, 01:19 PM | #17 | |
All about them Ks
Its the same in the square body years for the 1/2 and 3/4 trucks, the K30 frame in the sqaure years is 100% different and 100% beef lol. I doubt this post is still relevant to the OP but I would have used the original frame and not thought twice.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5 lift, 35s, front dana 60 blah blah blah http://67-72chevytrucks.com/vboard/s...d.php?t=662879 69 K10 SWB: 4 lift 33s in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20s |
02-26-2023, 06:56 PM | #18 |
This is an older thread, but the GVW is less on a 4wd prolly cause of the front axle. I'd imagine the frames are the same thickness, but the front axle would be the weak link.
02-27-2023, 02:39 AM | #19 |
Do not think the front axle is a weak link. The weight of the front axle is more and it just takes away from the overall GVW.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
02-27-2023, 11:13 AM | #20 |
SS Tim provides great information and comparisons in this thread(post #9)... a must read for you.
http://67-72chevytrucks.com/vboard/s...d.php?t=659340 I would run the frame you have, beat it like a rented mule. If(IF) the frame ever cracks... repair it by bolting on flitch plates or an inserted piece of channel iron. Never weld your frame when you can do otherwise. The K frames were designed to flex, in lieu of cracking under stress. Another two cents... worth the price paid. Good luck! j
White K20 |
