Old 08-25-2016, 07:42 PM   #1
Clavo106
two piece to one piece drive line swap.
My truck c10 has a th400 with and 1968 1/2 ton diff. Has a two piece drive line. Im all ready cut the frame and and welding everthing up (lond bed to short bed) just doing mock up stuff now.. I was planning on running the two piece. But if I could go one piece and pick one up from a wreck yard and have a shop cut it down.to fit.... what would I need to get this done...fit and vehicle wise to look for?.. done easy I guess.. lol..
Clavo106 is offline   Reply With Quote
Old 08-25-2016, 07:54 PM   #2
ck5566
Re: two piece to one piece drive line swap.
If your front yoke and all the rest of the drive shaft did fit and is in good working order be for the chop down you already had mentioned using a shop (Drive Shaft Shop) then just bring all of the drive shaft to the shop and have a new one put together for you. Or you can look for one from a short bed truck from the bone yards. Not a difficult thing to do, well finding a short bed drive shaft might be difficult.
ck5566 is offline   Reply With Quote
Old 08-25-2016, 08:32 PM   #3
nightrider388
I have had several short beds and everyone of them had 2 piece drive shafts. The 2 piece is actually stronger and works good with a nice carrier bearing. But I'm sure there are more knowledgeable gurus on here that can guide you in the right direction.
nightrider388 is offline   Reply With Quote
Old 08-25-2016, 08:43 PM   #4
Grumpy old man
Grumpy old man's Avatar
Too bad your so far away I have a stack of them .
Check with DLtruck he was parting a bunch of trucks and is out your way .
Old 08-30-2016, 12:00 PM   #5
brad_man_72
the boat guy
brad_man_72's Avatar
If you value your time and money have a new shaft made by a reputable driveline shop.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 08-30-2016, 07:18 PM   #6
CaptRMW
Custom Sport W/T
CaptRMW's Avatar
Location: Tarpon Springs,Fl & Annapolis,Md. ....................Quaint drinking villages with a fishing problem
Take your measurements to the boneyard and you will find one. Change over U-Joints are available from Auto Zone if you need innie to outie joints. I am running a one piece from a Caprice of about 1990 vintage but not sure how long it will last as I have only put 334,000 miles on it...
CaptRMW is offline   Reply With Quote
