Easier to fix or replace?
So my wife sent me this pictures from after my kid was playing in the truck. Would it be easier to fix it or should I just go with a replacement?
![]() Join Date: Dec 2013
Re: Easier to fix or replace?
there are 2 steel studs mounted in the floor it should just snap back on .if the bottom of the plastic pedal is worn/broken you can just order another and re use the chrome
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
#3 | |
http://www.classicindustries.com/pro...ts/cx1216.html |
never mind, looks like it will need to be replaced
#5 | |
(In all seriousness, just get a new pedal, they're cheap and fairly accurate in reproduction).
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
Heres my luck.
I bought new studs and peddle and one side of the peddle broke at the hole just pushing it on. O well they are cheap enough too get another one. Im not sure if quality is better from differnt vendors or not but mine came from the cali. Truck shop. it seems like a harder more brittle plastic than the oe peddle.
81 camaro 355 4/spd 342 posi my first love ![]() 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
