08-26-2016, 03:45 PM | #1 |
396 Oil Pan
Suggestions on a good stock oil pan for the truck.
Unsure on quart size capacity. Want to ensure it clears crossmember Thanks |
08-26-2016, 11:48 PM | #2 |
60-66 Nut
Re: 396 Oil Pan
As far as I know any car or pickup oil pan should fit. Many of the medium duty trucks have larger capacity pans that may or may not interfere depending on where you position the engine. I have a Moroso 8qt pan on the 454 in my Suburban, but that wouldn't be a good idea on a lowered truck.
08-27-2016, 09:12 PM | #3 |
Re: 396 Oil Pan
a oil pan for a 66 chevelle big block is a good one for good cross member clearance .
I bought mine on ebay new . |
08-29-2016, 10:00 AM | #4 |
Re: 396 Oil Pan
x2 on the Chevelle oil pan. Plenty of clearance on my cross member.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
08-29-2016, 10:49 AM | #5 |
Re: 396 Oil Pan
any suggestions on source?
I wasn't sure about the aftermarkets vs. the GM originals. |
08-30-2016, 09:18 AM | #6 |
Re: 396 Oil Pan
I used GM original chevelle big block oil pan. Think I paid $25 on craigslist.
Not the best pic, but you can see the clearance here
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 08-30-2016 at 09:23 AM. |
08-30-2016, 09:25 AM | #7 |
Re: 396 Oil Pan
good info. what quart size is stock?
08-30-2016, 11:40 AM | #8 |
Re: 396 Oil Pan
Stock BBC oil pans were 5 qts and I run a 1 qt filter
08-30-2016, 04:39 PM | #9 |
Re: 396 Oil Pan
08-31-2016, 03:51 PM | #10 |
Re: 396 Oil Pan
I'm running a 396 on a drop member'd 65. obviously the drop member raises and moves the motor forward but i didn't have any clearance issues when i was running the stock suspension. i did end up getting a new replacement pan from summit without any fitment issues. Hope that helps.
08-31-2016, 10:49 PM | #11 |
60-66 Nut
Re: 396 Oil Pan
There is a bit more room with a pickup suspension crossmember than there is in a car such as a Chevelle or Camaro. Most any BBC oil pan should fit short of one of the large sump pans found in the medium duty trucks.
