Old 08-31-2016, 12:49 AM   #1
jserrato714
jserrato714's Avatar
65 c10 short bed daily driver budget build
Well let me start off by saying that it's good to be back on here. It's been a while since I have had a project Chevy. I bought this shorty this past Sunday in the I.E So Cal. Drove her home and began by removing the front clip and worked my way to the motor and granny shifting 4 speed. Today I removed the engine and trans for a light rebuild on that 327 SBC. After much thought I have decided to covert to auto tranny for some daily crusing . Turbo 350 or t400. This is a original truck inside an out. I plan on adding power steering, power front disc brakes , and a nice static drop. On the paint the plan is to rub some gibbs oil after cleaning to try and preserve the original # 512 GM paint . (Rare)Maybe some flat clear..feed back welcomed..
I will upload pics as I go.
jserrato714 is offline   Reply With Quote
Old 08-31-2016, 02:10 AM   #2
Praxiss454
Praxiss454's Avatar
Re: 65 c10 short bed daily driver budget build
Looks nice. Must have been pricey!
1965 GMC 1000 SWB Fleetside L6 230 - SOLD
Thanks everyone for the help over the years.
Praxiss454 is offline   Reply With Quote
Old 08-31-2016, 08:28 AM   #3
jserrato714
The owner held out on me for a week. He was asking 6500 on craigslist..after a week of flakes and lookie lous..I scored it @ 4000 for a running short bed.. Out here in cali thats cheap. Here are some more pics.
Old 08-31-2016, 08:52 AM   #4
Mathew21
Mathew21's Avatar
I like your plans for it. I rub mine every once in a while with Gibbs oil also. If you decide to go with a flat clear post up pictures. I have thought about that too. But the Gibbs does do a great job at protecting it. I'm subscribing to this thread.
It only has original paint once
Mathew21 is offline   Reply With Quote
Old 08-31-2016, 08:56 AM   #5
jserrato714
You got it boss...Im thinking gibbs is the way to go..cheaper of course
Old 08-31-2016, 10:06 AM   #6
jchav62
1962 C-10
jchav62's Avatar
Score! I love it. I dig your plans too. Looks to have come from my part of the country... New Mexico Plates. Mora County??
Congrats!
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 08-31-2016, 12:04 PM   #7
jserrato714
Thanks man. Its a cali plant truck...came from Taos County New Mex
Old 08-31-2016, 11:28 PM   #8
Captainfab
60-66 Nut
looks like a good score to me
Old 09-03-2016, 12:17 AM   #9
jserrato714
So I took the camel hump heads to the shop for a hot tank bath...tore the motor apart and
Came across a mickey mouse repair...coolant was probably leaking at one point in time into the block. They added a piece of aluminum with screws and lots of cylicone for the repair. Block is bad in my book and I wont try and repair. Sad b day in my book..
Old 09-03-2016, 12:20 AM   #10
jserrato714
Last pic of the tub is all the crap I took off from the front end...getting ready for some fresh paint.
Old 09-04-2016, 01:28 PM   #11
Bomp
Bomp's Avatar
That failed repair is pure evil in my book.
Glad the truck is in your hands.
Sub'd
Bomp is offline   Reply With Quote
Old 09-04-2016, 02:41 PM   #12
jserrato714
So upon searching on craigslist I came across this sbc 350 with new matching transmission. And other parts. Took it apart for inspection. Looks super clean inside and out. Added new gaskets and pump and called it a day. Last pic is of the frame rattle canned black .As you can see the tranny is still in . I have to cut the manual cross member out so it can fall in one piece with drive shaft.
Old 09-05-2016, 12:19 PM   #13
rusty76
rusty76's Avatar
I'm in. Cool truck.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 09-05-2016, 12:49 PM   #14
jserrato714
Thanks man..sorry about the pics...not sure why it uploads then side ways .
Old 09-06-2016, 03:06 PM   #15
jserrato714
Looking for some feed back...I put the oil pan and intake manifold using felpro gaskets..Not sure if anyone has had trouble with the cork gaskets after installation. I feel I should maybe use only rtv or right stuff...The intake manifold I used the rubber bridge gaskets and some rtv where it met the side head port gaskets.
Old 09-13-2016, 12:51 AM   #16
jserrato714
So I put in my sbc 350 with th350 today..and ran in to a problem...I bought a cpp 350 trans
Tubular crossmember and have no clue how it bolts on.. Also my tranny extends over the crossmember for the cable parking brakes.. Do I have to remove it...feed back please or. A link would be awesome. ..
Not sure why my pics upload sideways...sorry
Last pic is off a google search...my mount wont go in that way as the end tabs are welded in different spots.
Old 09-13-2016, 08:48 AM   #17
jserrato714
Anybody??
Old 09-13-2016, 11:55 AM   #18
TJ's Chevy
TJ's Chevy's Avatar
Looks to me like you have the older style parking brake cable assembly that required a cross member. If you convert to the 66 style the cross member is removed. I have a tremec tko600 in mine and am thinking of getting this tubular cross member. Only thing is I am not sure if it will work with the tremec. Looks like in the last pic showing the cross member installed the truck has a 66 year parking brake setup. Probably what your gonna have to do is remove it.
Old 09-13-2016, 02:26 PM   #19
jserrato714
Thanks for the feedback...any Ideas as to the black cpp crossmember..Is this the correct position to bolt on. My parking brake dont work now ..so maybe I can remove everything and replace as I go .
Old 09-13-2016, 02:30 PM   #20
TJ's Chevy
TJ's Chevy's Avatar
Since the parking brake cross member looks like it will unbolt and slide off....I would do that and then position the cpp member in the place where the tranny holes are. Then you can see what position it needs to be in and weather or not it needs a spacer...the only real reason one is there is to help keep things tight against the torque of the motor. Long as everything is Tight it shouldn't really matter how the member is installed. A 350 really doesn't have enough guts to break something unless it's supercharged making 600+ hp. haha
Old 09-13-2016, 02:49 PM   #21
jserrato714
Thank you sir
Old 09-22-2016, 12:31 AM   #22
jserrato714
So engine is in and the tranny is bolted and in place with a cpp tubular x member.
Got all the plumbing done as well as some new gauges under the dash..will load pics tomorrow. Just waiting on summit racing for the spark wires..also I need to run a keyed hot for
the new hei distributor. I also need a trans cooler...thinking of going to oreillys and getting a hayden since its cheap and I am at stock hp.. Went ahead and shoped for a floor shifter for my th350..loved the lokar shifters but not the price. Ended up with a american shifter single action with a 23 " shifter could not beat the price at under $200. Heres a picture of that installed.
Sorry for the sideways pics again..not sure why they upload this way.
Old 09-22-2016, 12:36 PM   #23
siggyfreud
siggyfreud's Avatar
Looking good! I'm also using the CPP trans crossmember. I haven't bolted it down yet though. Need to drill new holes in the frame for it.
siggyfreud is offline   Reply With Quote
Old 09-22-2016, 02:20 PM   #24
jserrato714
Well my truck had the e brake crossmember so I removed that and then the x member used 1 hole. i had to drill on the crossmember using a existing hole on the frame. Keep in mind this is for a th 350 with a 6 " tail..
Old 09-22-2016, 02:21 PM   #25
aggie91
I'm just glad to be here!
aggie91's Avatar
Nice work so far. I had to remove my e-brake cross member on my '65 too so that I could run a similar trans mount cross member. I converted over the e-brake cable to a universal set...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
