Bit of play at bottom of column
Hello and good evening,
First off, thanks to all who participate and post on here. My truck coming together nicely because of all of you. Now to my issue. I've purchased a tilt rebuilt column from a van. Went on fine, but at the bottom of the shaft there is a bit of play. I don't mean turning the shaft, more like up and down and side to side. It's a little bit, but wondering what tightens this up. I know that with the tilt, the spring and retainer washer from non-tilt isn't used. Another thing, I'm using a u-joint, would the factory shaft tighten things up? Any help would be appreciated. Thanks |
Re: Bit of play at bottom of column
The play I have is here..
![]() Join Date: Nov 2007
It looks like the clip which retains that lower bearing is missing.
It also looks like it is not new, and luckily the lower bearing is still available and is not expensive.
Running in place gets you nowhere fast. -me 1968 GTO 4-spd covnvertible 1970 K-20 4-speed, factory AC. |
Sorry I forgot.. I have the retaininer and clip, I just happen to take it off right before the pic to check bearing..thanks tho
Play there simply means the bearing is somewhat worn (or out of spec). Or, you're missing the o-ring that sits between the bearing and the shaft. I put a new bearing in mine, but it still has a little play... that's LMC for you.
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER 1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD 1976 Trans Am | 400/4-spd | SOLD 1976 Trans Am | 455/4-spd | TOTALED ![]() |
Hey thanks joeydurango. The column is rebuilt and had new bearing. The play just seemed like too much. So what I did was take the bearing out, replaced it with my old one (which fit tighter on the shaft) and it solved my problem. It does still have a little play/floats but my steering definitely stiffened up.
Again thank you. |
