09-07-2016, 07:06 PM | #1 |
Bagged, turbo LS, 59 Apache build
Hello - I am new to the board but have been a long-time lurker. Figured I would post some pictures of my 59 which has been going through a transformation for the last 10 months.
The project started off with what I thought was a good, driver quality truck that had been "updated" in the late 80s and again in 2003. It had a mild SBC, 700r4 and some nice accessories like a March serpentine system, Vintage Air, BeCool radiator, etc. Unfortunately, it also had the most poorly fab'd rack/steering box/column config you have ever seen and as a result, it handled like a shopping cart. It was scary. So, since it had already been cut on we decided it was a good starting point for a bagged, LS sleeper. In January of this year, I dropped it off at Hale's Speed Shop in Lewisville, TX and things got moving pretty quickly. I missed a few pictures at the start of the tear down but it was stripped to the frame in 1 day. We were able to sell the entire drive train to another gear head Chassis fab under way with 4 link, bag mounts and temporary rear end. Front end was setup and LS motor mounts were fab'd using a plastic LS block. Around this time, Nathan Hale convinced me to go with a turbo and you can see the turbo manifold in this pic. |
09-07-2016, 08:16 PM | #2 |
Re: Bagged, turbo LS, 59 Apache build
09-07-2016, 09:01 PM | #3 |
Gonna be a bad ride when you get back on the road..looks good..
09-26-2016, 12:52 PM | #4 | |
I just took on another build a 58 Apache that I'm bagging, got it laid out with a heidts mustang II front and narrowed control arms but the arms stick way way up and liked what you did. What size rims and tires are you using? Posted via Mobile Device |
09-07-2016, 10:00 PM | #5 |
What a tease...
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
09-07-2016, 10:38 PM | #6 |
Built LQ9 (6.0) should make just over 1,000 HP to the tires with 88MM turbo....on pump gas.
Should be on the road this month and will ride just a little higher than it appears here. |
09-07-2016, 10:43 PM | #7 |
Wow looks awesome and happy to see another LS build, I can steal ideas off of.. lol
What Oil pan did you use and is the passenger back valve cover just about to touch the firewall? Thanks!! |
09-07-2016, 11:02 PM | #8 | |
The oil pan is from an F body (Camaro). It's GM part # 12558762. |
09-07-2016, 11:10 PM | #9 |
1000hp...88mm turbo...dang it boy..you gonna have to give more details than that..haha..I agree with 71 4x4...you just teasing us..
09-07-2016, 11:30 PM | #10 | |
The intake is a Holley Hi Ram with 105MM throttle body and 160# injectors. Transmission is a Tremec T-56 Magnum with a McLeod RXT clutch. Rear end is a Ford 9" from Quick Performance. |
09-08-2016, 06:40 AM | #11 |
Incredible detail on the frame. Keep the photos coming. dug
My Build - http://67-72chevytrucks.com/vboard/s...d.php?t=515876 |
09-08-2016, 10:20 AM | #12 |
welcome.
Very cool build. Should be pretty wicked when done. Kim |
09-08-2016, 10:36 AM | #13 |
Camaro/firebird fuel tank?
09-08-2016, 11:07 AM | #14 |
The tank pictured was just used during fabrication. The one in the truck now is the same size but is an Aeromotive Stealth for a 64-68 Mustang.
09-09-2016, 11:16 AM | #15 |
Nice.
Holley Dominator EFI ??? |
09-09-2016, 06:46 PM | #16 |
09-10-2016, 02:25 AM | #17 |
"59"
That rear suspension is real slick.... What a nasty looking mill. Keep on keepin on Nut Case
Been there, wrecked that |
09-15-2016, 09:24 PM | #18 |
Here is a pic of the transmission tunnel a few people have asked about.
09-15-2016, 10:46 PM | #19 |
Wow Looks Awesome and Thanks for the Information on the Oil pan and motor placement!! That is a huge help to me and looks like now ill be doing a tunnel after seeing your last pic!! Truck looks awesome and any chance you have a pic of the driver side of the motor with the steering?? Thanks Again and cant wait to see more!!
09-21-2016, 04:10 PM | #20 |
Nice build!!
Just read it and want to see more!! Motor is looking pretty Angry
Cheers!! Kees. 1959 Chevy Fleetside Longbed My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426 Kool Guyz CC Instagram: _King_Kustom_ |
09-21-2016, 05:43 PM | #21 |
A320 Pilot/USAF Retired
Great build! Please post lots of pic's!!!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
09-21-2016, 09:06 PM | #22 |
Very cool build, love the tunnel
09-25-2016, 11:38 PM | #23 |
This is such an awesome build! Love what Hales Speed Shop is doing.
09-26-2016, 01:30 PM | #24 |
Hale's makes some very cool rides. Should be fun with all that HP. I don't understand why they 2 link everything though. I would think that with the amount of work and time put into each ride they would opt for a better rear suspension set up.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
10-02-2016, 10:59 AM | #25 |
Rolling to Good Guys Lone Star Nationals today.
Tags |
bagged, t-56, tremec, turbo ls |
