Old 09-07-2016, 09:42 PM   #1
saxart
saxart's Avatar
How wide are my rims?
Is there a way to tell how wide the original steel rims on my '70 are? I'd like to put wider tires on, but don't know how wide these rims are.
Are they stamped somewhere on the outside? Thanks!
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801
saxart is offline   Reply With Quote
Old 09-07-2016, 09:54 PM   #2
franken
Re: How wide are my rims?
It sounds complicated, but its not hard. Take some 1x2 or whatever and strap or tape horizontally at the center line of the tire on both sides inside and out.
Measure the distance between.
Next measure from the 1st parallel flat surface to the board on both sides. Add those.
Subtract that number from the earlier one and round to the nearest inch.
My guess is 6"
Old 09-07-2016, 09:59 PM   #3
71swb4x4
71swb4x4's Avatar
Looks like 6" from here.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 09-07-2016, 10:05 PM   #4
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Should be stamped on the inboard section of the rim. Not inside the tire though, the tire stays mounted. Remove the lug nuts, flop the wheel over, you should see it. Sometimes I am horrible at trying to get my point across....
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 09-08-2016, 08:41 PM   #5
saxart
saxart's Avatar
LOL Makes sense! I pulled a wheel today, actually two wheels, and there was no stamping on either one. So... I shoved a ruler through the slots in the wheel and used a straight-edge to get a measurement. Looks like 5-1/2" rims. Ugh! No wonder 235's look like they're bulging out.
Anyway, I'm thinking of going to 265's or 275's. Who sells 15" 6-bolt steel rim (7-inch?) that will fit a tire this wide?
Thanks!
Old 09-07-2016, 10:05 PM   #6
LongBox
My truck lists the rim size on the SPID, but that may be only in the case of an optional rim size.
Rick
-69 GMC 910 Long Box, 350
-98 Chev Silverado 1500, 350 Vortec 4L60e
-08 Mustang GT Convertible
LongBox is offline   Reply With Quote
Old 09-08-2016, 11:31 PM   #7
franken
You might think about any 73-87 4x4 Blazer or half ton truck 4x4 rally style wheels. I think all were 8".
You can run w/ or w/ trim rings and caps as preferred.
Old 09-09-2016, 12:56 AM   #8
saxart
saxart's Avatar
Thanks Franken. I forgot to mention, I'd like to keep the stock hubcaps, so I'm looking for a non-rally rim with the hubcap "nibs".
Old 09-09-2016, 05:02 AM   #9
TwoFiftyShifter
Not sure about which rims to buy. But for a 265 series tire I recommend 8". Its perfect - I'm running that out back right now. A 7" rim makes a 265 balloon out in my opinion.
Beautiful truck
1982 K10 SWB
1987 V20 - Sold - Doh!
TwoFiftyShifter is offline   Reply With Quote
Old 09-09-2016, 08:16 AM   #10
68Gold/white
Most all 67-70 6 lug wheels I've seen are 5-1/2 inches...
68Gold/white is offline   Reply With Quote
Old 09-09-2016, 01:01 PM   #11
Stocker
20' Daredevil (Ret)
Stocker's Avatar
FWIW, our Tacoma came with 265/70s on 16x7" wheels and it seems like a good fit. Lots of folks upgrade to 265/75, same width but an inch taller. However many 265/75 are LR-E only which is fine for a heavier truck, but overkill for a typical mid-size. At any rate an 8" wheel should also work well for a 265-series tire.
- Mike -
RIP El Jay
Old 09-09-2016, 10:43 PM   #12
saxart
saxart's Avatar
Thanks for all of the thoughts!
So, if I'm looking for an 8" wide 6-lug steel rim that will hold a factory hubcap, does anybody make those? The closest I'm seeing online is the Vintique "Smoothies" on Summit. (I don't think those will hold a hubcap though)
No offense, but I'm not a fan of the Rally rims. Just looking for an 8" steel rim that will hold a hubcap.
Old 09-09-2016, 11:31 PM   #13
71swb4x4
71swb4x4's Avatar
These are what you want. Check the parts board, there are usually some for sale.
http://67-72chevytrucks.com/vboard/s...d.php?t=688899
Old 09-09-2016, 11:43 PM   #14
1969_CM2590D
1969_CM2590D's Avatar
If you have your SPID on the glovebox door it's a cinch on something original. Go to the GM Heritage Center online. You can download the 1970 salesman's Truck Fact Book which is chock full of all sorts of technical and option info. Just match the option code on the SPID to the wheel/tire chart in the book and you'll see the rim width listed as part of the data.
Voila! Here's the link: https://www.gmheritagecenter.com/doc...olet-Truck.pdf
Dennis Nichols
1969 GMC C2500 305E V-6 The Mule
1986 Toyota 4Runner
1959 MG MGA Coupe
1969_CM2590D is offline   Reply With Quote
Old 09-17-2016, 01:34 AM   #15
1969c10joe
when i bought my truck the tires were oversize so tall they hurt acceleration didnt corner well either I had tire shop measure rims I let the owner select my tires and im very happy
1969c10joe is offline   Reply With Quote
Old 09-17-2016, 01:41 AM   #16
1969c10joe
there was a company that could widen rims I was considering getting getting a wider tire on my motorcycle that was 25 yrs ago. wider stock looking rims make for a great sleeper!
Old 09-17-2016, 03:37 AM   #17
FarmYard
FarmYard's Avatar
275's with 73+ rally wheels
FarmYard is offline   Reply With Quote
