Old 09-14-2016, 12:18 AM   #1
vetnat
Need help identifying rear end
Hi. My truck is a Canadian built 1961 GMC half ton. It has a 10 bolt rear end with the number 0707340 stamped on the differential itself. I cannot see a number on the axle tube because there is a bracket on the passenger side covering where I think the numbers would be. This picture is off the internet, but looks identical to the one in my truck. Any help much appreciated.
1961 GMC half ton, short step, Canadian model. Just starting work on it.
vetnat is offline   Reply With Quote
Old 09-14-2016, 01:27 AM   #2
62stepside longbox
62stepside longbox's Avatar
Re: Need help identifying rear end
This question gets brought up quite often on here, not a gm 10 bolt, your rear end is an eaton ho32, used on 55-62 trucks. Most are posi with a 3.90 gear ratio. Good rear ends but pretty hard to find parts for. These are easily identified by the panhard bar mount, differential cover and removable third member
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 09-16-2016, 01:30 AM   #3
vetnat
Awesome. Thanks so much for the help. So, I think mine is posi, but the worn out kind. It is on jack stands in the rear currently, when I turn one wheel, the other wheel stays stationary. I read somewhere all older Eaton posi units used the same size clutch plates?
Why I was wondering in the first place, was I bought rear axle brake lines from Classic Industries and they didn't even come close to fitting. Anybody know a source of repro brake lines for this rear end?
Old 09-16-2016, 10:53 AM   #4
62stepside longbox
I'm not sure if brake lines are reproduced for this rear end but it would be wise to invest in a flaring kit do you can flare and bend your own brake lines
