Aftermarket Steering U-joint
Hello friends.
I just installed an aftermarket tilt steering column in my 67 C-10 and I am having difficulty finding the correct U-Joint. I cut the lower shaft at 16.5 inches from the rag joint to the upper 3/4 inch 36 spline on the end of the column shaft. I now have a cut collapsible lower, 1/2 inch gap, and spline shaft to steering column through fire wall. Which U-Joint is the correct fit to join this up? Anyone know a part number or correct label to order this joint? Thank you in advance! |
Re: Aftermarket Steering U-joint
I used a flaming river column and the part number for u joint I used was Flaming River Billet-Joint Steering Universal Joints FR1715DD
1970 K20 1967 Blown Stepside 2016 Chevy 2500 Duramax 1989 Jeep Cherokee 1995 S-10 2014 Infinity Q-50 AWD 1970 Chevy K20 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=634164 1967 stepside rebuild http://67-72chevytrucks.com/vboard/s...d.php?t=684913 Shop build http://www.garagejournal.com/forum/s...d.php?t=225559 |
The U-joint has a set screw...drilled the shaft for the set screw to seat in. I can take a pic of it installed tomorrow when I'm working on the truck if you'd like.
#5 | |
Thanks for the info!!! |
