60-62 rear bolt-in kit
I just joined this forum, but I have been a loooong time follower! Keep up the good work everyone!
I developed this kit about a year and a half ago, but I am now ready to start making small batches of these assemblies and wanted to see if anyone might be interested..... Brief Details: .188" thick material construction. Retains the x-frame. Converts trailing arms to a four link w/panhard. Almost 100% bolt-on (requires welding at the axle) https://www.instagram.com/p/z73q9tsR...=psukraw&hl=en https://www.instagram.com/p/xNow_CMR...=psukraw&hl=en https://www.instagram.com/p/2H4RQOMR...=psukraw&hl=en https://www.instagram.com/p/3SSsKzsR...=psukraw&hl=en https://www.instagram.com/p/3SS8mYsR...=psukraw&hl=en https://www.instagram.com/p/3STOXbsR...=psukraw&hl=en Thank you for looking! Last edited by psukraw; 09-16-2016 at 05:53 PM. |
60-66 Nut
Re: 60-62 rear bolt-in kit
Looks good to me aside from the lower shock mount.
60-66 Nut
In your description you say that the lower shock mount is a layered design. It bolts between the lower bag mount and the bag. IMO that design will eventually break. It should be braced against the axle tube or the lower bag mount. It could be either bolted or welded.
#5 | |
Here is a screen shot of what I was referring too. Thank you for looking. Last edited by psukraw; 09-20-2016 at 06:43 PM. |
Just throwing it out there. I just had a new 2 piece driveshaft built by Adams Driveline for my '62 Short bed with pipe notch. What did you do for a carrier bearing mount?
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
wow I couldn't even want a hood when I was pink
![]() Join Date: May 2014
i like it. i run a 62. would be cool if you made it without such a huge notch too though, for those that dont need to be that low, and want to retain some bed space.
Current Project : 1962 Chevy SWB Fleetside Others, 1958 Edsel Villager Station Wagon 1926 Ford Model T Roadster Hotrod www.suedescarclub.com |
I put a 2.5" notch in mine of which the pumpkin pokes through at full drop. But now I am limited by exhaust so the notches are useless as far as axle would stop at frame if not for shocks or bumpstop. So before you cut consider this.
The bed sits on the frame at the notch.
I'm interested pending price.
Would happen to have an overhead shot of the kit installed?
1962 Chevy C10 Short Fleet My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=692962 |
#15 |
ive already notched mine. I know id have to go into the box to get it lower. but i dont need to lay it on the rockers.
