09-16-2016, 11:20 PM | #1 |
rear end difference
does anyone know the differences in the gap between the mounting pads on a 1960 to 62 rear end and a 63 to 72 rear end? I am trying out figure out the space difference.
09-17-2016, 08:26 AM | #2 |
Re: rear end difference
Space is an issue but the angle of the mount could also be an issue
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
09-17-2016, 09:31 AM | #3 |
Moderator
There also at an angle so at what point would the gap be measured?
09-17-2016, 10:10 AM | #4 |
correct. I know the length of the trailing arm (the are the same.) so if I can get the gap from the backside of the mounting pad or the ends of the 2 trailing arms I can figure out the different angles. which is ultimately my goal. I have a 60 so I need the gaps on a 63 to 72.
09-17-2016, 11:42 PM | #5 |
60-66 Nut
I really don't understand what this 'gap' is that you are talking about.
09-17-2016, 11:54 PM | #6 |
either the gap between the 2 mounting pads on the rear end, or the gap between the rear end of the trailing arms either one will work.
the gap between the front mounting points of the trailing arms would be great but I can figure that out if I need to. |
09-18-2016, 12:16 AM | #7 | |
But Found Her 25yrs Later!
http://67-72chevytrucks.com/vboard/s...10#post7357010
09-18-2016, 12:26 AM | #8 |
thanks, but what I need is the measurements I have the length of the trailing arm, I have the gap of a 60 to 62 I need the gap of a 63 to 72 so I can explain the different angles of the separate years
