![]() Join Date: Nov 2012
BEWARE of inline fuses...😠
Today when I was working on my 81 Stepside that just got out of the paint shop I had to reach under the dash to replace a bulb in the gauge pod. When I did this, I must have slipped a wire insulating piece of electrical tape off the power wire on the radio and it grounded. The next thing I knew my radio was smoking all over the place and I had to go under the hood and disconnect the battery. Unbelievably my factory original DELCO AM/FM radio still works, but I am worried that the wires in it may be FRIED. What I cannot understand is that grounded power wire has an inline fuse in it and this fuse did not blow for some reason. If the wires were cooking the fuse should have popped but it did not. Be very careful with inline fuses folks. Today I learned my lesson.
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed http://67-72chevytrucks.com/vboard/s...d.php?t=584617 PROJECT JIGSAW 1967 GMC C3500 GREAT WHITE 1986 Blazer M1009 |
Re: BEWARE of inline fuses...😠
How many amps was the fuse? Should be no more than about 3Amps. It also makes a difference if it grounded in front of the fuse where the fuse would not have been effective. In this case the radio would not have been affected by the ground as the wire would have short circuited between the fuse box and the ground point. Moral of the story= put your inline fuse closer to the fuse box and always use either shrink tube on soldered connections or liquid electrical tape. NEVER EVER use adhesive electrical tape on your truck. Or much of anything anymore. I only use it on frayed cable ends or temporary situations. I always use liquid tape over it though. Never unravels and looks better too. It works well on the printed circuits on the back of your dash cluster as well. Just solder broken connection and cover in liquid tape. End Ramble.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
Just a future tip for you, I put heat shrink on all my connections, even crimp connectors.
A fuse is going to do the same thing whether it's inline or in a fuse box. I don't think it's an issue with an inline fuse. I agree with where jj is going, probably an improperly sized fuse.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
I use crimp connectors too but I never crimp them. I solder them up. I first remove the standard plastic junk thing that never works where you would be crimping, Then slide up your shrink tube, Solder the connector, Slide the shrink tube on and bam. Nice looking almost stock look and will never come apart.
#5 | |
Chris _______________________________ 1979 Chevy Stepside SPORT 2018 Chevy Silverado, 39 years apart ![]() My build 2008-2016. http://m.imgur.com/a/bURrE |
Perhaps the name of the store it should have been "Beware of electrical tape". I installed the radio about seven years ago in the truck. When I had it painted the man who did the paint job took it out and then put it back in. I guess the tape must have come loose then and neither of us knew about it. I think I'm going to follow some of the good advice that was given me on here.
