Old 09-20-2016, 03:05 PM   #1
jayoldschool
Moderator
Frame stamp help
Working on my buddy's truck, and came across the frame stamp under the passenger door. Wondering if someone can help me decode it. I think the last few digits are obvious:
3829596 10 2 62
Are the first group of digits a partial VIN?
jayoldschool is offline   Reply With Quote
Old 09-20-2016, 03:22 PM   #2
padresag
Re: Frame stamp help
look like a part nbr... otherwise they would match the nbrs on the serial plate
ron
padresag is offline   Reply With Quote
Old 09-20-2016, 03:25 PM   #3
The Rocknrod
Moderator
The Rocknrod's Avatar
VIN Number locations including frame: http://67-72chevytrucks.com/vboard/s...d.php?t=316902
Old 09-20-2016, 08:04 PM   #4
60-66
60-66's Avatar
Ron is correct 3829596 is the frames part number the other numbers are the date . These are stamped on the side of the frame . The VIN is on top of the frame.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 09-20-2016, 10:40 PM   #5
jayoldschool
Moderator
Perfect, thank you gentlemen, I'll check the other side for the VIN tomorrow! Can't believe how clean this thing is. Looks like it was stamped last month.
Old 09-20-2016, 11:48 PM   #6
padresag
chev or gmc. if it is a chev it will all be on the drivers side on top by where the steering box is or by the rear cab mount
ron
Old 09-21-2016, 09:36 AM   #7
jayoldschool
Moderator
Ok, here's what's on the frame:
0107330
Looking at the decoder... I'm not sure how to break it down. It's likely a Canadian truck if that helps...
Old 09-21-2016, 10:55 AM   #8
padresag
does it match the back part of the ser#
ron
Old 09-21-2016, 04:55 PM   #9
1963c-10
1963c-10's Avatar
I'm think #107330 of the line
1964 Short bed trailer
Old 09-22-2016, 11:27 PM   #10
Clif Dzzzz
Clif Dzzzz is offline   Reply With Quote
