10-07-2003, 08:45 PM | #1 |
Above the Frame?
I need a good fitting set of headers for a 67' with a 350 that don't hang below the frame! If anybody has any suggestion's they would be greatly appreciated. Thanks Dewayne
10-07-2003, 09:27 PM | #2 |
I am a Referee of life.
Best guess. I would suggest you check out the street rod shorty headers.They make them to fit just about anything.I think all full legnth headers will hang below the frame.You might also check with a four wheeler shop, the rock crawlers don't want to hang anything up under their trucks.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
10-07-2003, 09:36 PM | #3 |
Fabricate till you "puke"
For a full lenght header, me thinks you are out of luck. Hooker comps hang about 2 1/4" below the rails on my longhorn. If your truck is slammed, you need a 3/4 lenght chevelle header, or a sandersen block hugger. I cant help with the part #, but Shane has chevelle headres on his truck, & I think Slammed 67 is running the Sandersens. Good luck, crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
