Axle education needed
I have a 98 Silverado with the GM 10 bolt rear, and my 69 has the 12 bolt. Is there any significant difference between these units? I note that the 10 bolt, which is considered a pretty light duty axle, has a higher axle weight rating than the 12 bolt. Any info would be appreciated, and thanks ahead of time.
Rick -69 GMC 910 Long Box, 350 -98 Chev Silverado 1500, 350 Vortec 4L60e -08 Mustang GT Convertible |
Re: Axle education needed
the 10 bolt is wider and also the 98 is leaf spring set up ,the 69 is a coil trailing arm set up /with pan hard bar (track Arm) you can convert eith set up just depends on how much work you want to due there will be som welding required
