09-22-2016, 05:30 PM | #1 |
Parting out 2005 Silverado
Hi all,
Recently came across a rolled 2005 Silverado that I snuck the engine, trans, and transfer case off of, as well as the radiator, fans, ac condenser, and wheels/tires. I figured I'd see if anyone needs anything off it. Interior is still good, as are the axles. Headlights, taillights, park lights, etc etc are still there. Just PM me or reply in this thread, I'll try to stay on top of it as best I can. Forum rules state a price is needed, but listing every single part available would be hard plus I'd still forget things people want. I'll say for $1500 you can have the whole pickup or make an offer on any parts you need. Located in Platte, SD 57369 Thanks! |
09-22-2016, 06:43 PM | #2 |
Re: Parting out 2005 Silverado
hows the driveshaft and xfer case crossmember?
1967custom |
09-22-2016, 06:46 PM | #3 |
Both are good, the vehicle drove just fine before I pulled the drivetrain. Measure your shafts and I'll double check that mine are the same.
09-22-2016, 06:48 PM | #4 |
just need the rear. ill get you measurements tonight.
1967custom |
09-23-2016, 02:45 PM | #5 |
My driveshaft lengths are ~67 3/4 rear and ~29 5/8 front, measuring from center of u-joint cap to center of u-joint cap.
09-23-2016, 04:08 PM | #6 |
its too long. crap.. ok man thanks anyways. can i get a pic of the xfer case crossmember?
1967custom |
09-23-2016, 04:10 PM | #7 |
Gone right now, I will take a picture as soon as I get back on Sunday.
09-23-2016, 05:16 PM | #8 |
67-72 parts collector,…
Does this truck have fog lamps under the front bumper?
If so I need a good complete wiring harness for them.
09-23-2016, 05:19 PM | #9 |
Yes it does. I believe it is part of the front lighting harness. Do you want the whole harness or do you want me to cut a chunk out?
09-23-2016, 06:57 PM | #10 | |
I thought it could be unplugged from the under hood fuse box. Definitely interested. Price shipped to 65251?
09-25-2016, 06:38 PM | #11 | |
Thank you.
09-23-2016, 07:06 PM | #12 |
Pm sent!
09-23-2016, 07:38 PM | #13 |
09-23-2016, 07:44 PM | #14 |
Oops, check now!
09-25-2016, 07:54 AM | #15 |
Interested in the exterior driver side rear door handle. Condition? Price shipped to 17044? Thanks
'76 C10 Silverado - 350/TH350 '87 R10 Silverado - 305tbi/700R4 '05 Silverado Z71 - 5.3/4L60e |
09-25-2016, 09:27 AM | #16 |
Pm sent!
09-25-2016, 06:41 PM | #17 |
Thank you! Will ship tomorrow, as long as I can find a good box at the shop.
09-25-2016, 06:45 PM | #18 |
All PM's should be replied to, let me know I missed you!
09-25-2016, 08:07 PM | #19 |
I've been disassembling, here is some pictures of what's available. I haven't spent any time cleaning the parts, so if you are interested but want to see how it cleans up, let me know and I'll hook you up.
Transfer Case Module, Body Module, XM receiver w/antennae, CD player, air bags, steering wheel w/controls, steering column, floor mats, almost all plastic trim, HVAC box (dual zone), HVAC controls, 4x4 button, fog light button, instrument cluster, fuse block, junction block, trailer brake adapter, headlight switch, hood release w/latch, e-brake release, wiper arms, overhead cubby, door sills, entire dash harness, etc etc... http://s160.photobucket.com/user/ant...muw56.jpg.html |
01-16-2017, 12:10 AM | #20 | |
I received the radio the other day - thanks. Should have asked if you had the two supports under cab part of the truck that bolts to the frame and to the flat part of the front suspension. They are round tubes with flat ends and holes to bolt them up. Mine on my 2004 are rusted through and I would like to replace them with better / more solid ones. Thanks, Jay |
09-25-2016, 08:07 PM | #21 |
09-26-2016, 08:55 AM | #22 |
09-26-2016, 11:47 AM | #23 |
09-26-2016, 04:53 PM | #24 |
GM Addicted
How much for power window conversion stuff
..Mac’s Garage.. 73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd My 73 GMC Truck Build Pic 2010 Silverado 4/6 on 24s IG:MacsGarage |
09-26-2016, 05:07 PM | #25 |
$300+ shipping for regulator, motor, switch, panel, and door wiring, both sides. Also have power locks available if needed.
