Old 09-25-2016, 12:58 PM   #1
Dazzoman
Thread locker /flywheel nessecary ?
Hi , Im an newbee here and have a 3/4 ton 1966 GMC ( since 1980 ! ) with an 292 , muncie grannybox that finally died - 50 yrs .
I'm retrofitting an 1980's NP440 trans - only two bolt holes fit the '66 bell housing . (For the other side we are making an strap/bracket more later on that ).
On flywheel shall I use the star washers and some red loctite on the flywheel bolts ?
Dazzoman
Dazzoman is offline   Reply With Quote
Old 09-26-2016, 12:10 AM   #2
jtrichard
Re: Thread locker /flywheel nessecary ?
Just use NEW star locks and torque wrench
jtrichard is offline   Reply With Quote
Old 09-26-2016, 11:53 AM   #3
Dazzoman
really? About 60 lbs ?
Old 09-26-2016, 12:30 PM   #4
jtrichard
Appears to be #60 you can use red loctite I always replace what ever type lock washer OEM used oil the bolts and torque I have never used loctite on flywheel bolts and have NEVER had any problems
Old 09-27-2016, 12:10 PM   #5
60-66
60-66's Avatar
I like your answer, jtrichard . Oil on the threads gives a more accurate torque , allowing the bolt to stretch a few thousands . No need for any liquid thread lockers.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 09-26-2016, 02:28 PM   #6
The Rocknrod
Moderator
The Rocknrod's Avatar
If it makes you feel safer use the star washers with blue loctite. I wouldn't use red.
Old 09-26-2016, 03:55 PM   #7
TJ's Chevy
TJ's Chevy's Avatar
New bolts and torque them to spec. Never had a problem. Maybe just a tiny drop of blue thread locker.
Old 09-27-2016, 11:03 AM   #8
Dazzoman
Thanks guys !
Teddy
