A/C Conversion Advice
I'm torn on whether to give up on my non a/c to a/c conversion or just bite the bullet and go with an aftermarket a/c kit (VA, Old Air, etc.)
I have a non a/c cab and purchased an a/c system on craigslist from a 70 chevy. (A/C box, condenser, old compressor, actuators, most of the brackets, etc.) I started the non a/c to a/c conversion by modifying the firewall and installing the a/c box with a new evaporator. The system I bought didn't come with the poa valve, and now I'm torn on how to finish this up. Do I go with a poa eliminator setup? Accumulator and orifice tube setup? Is it worth seeing if the old A6 compressor will work? Or should I go with a newer one? Any advice/help would be greatly appreciated!
Coop34 70 Chevy C10 5.7L TBI/700R4 |
#2 | |
Old member
![]() Quote:
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Re: A/C Conversion Advice
Thanks Andy. Which kit are you referring to? Would I need to get a different evaporator? Would I need to have hoses made?
If you need a rebuilt poa valve, I have them. This way you don't need to buy another evaporator. You could also get an aluminum modern version of the steel a6.
My aftermarket old air kit sucks. It will be coming out this winter and replaced with a original ac system
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
Thanks for the tips. I'm leaning towards finishing up the factory A/C, but not sure about which compressor and valves. A6 or sanden? POA, POA eliminator with cycling, or accumulator/orifice tube setup. It gets well over 100 degrees here in the summer.
Moderator
![]() Join Date: May 2007
If you are installing a factory system, go with an aluminum aftermarket replacement for the A/6 that fits the brackets/hoses. Use R-12 and have a system that works as it was designed and will freeze you out of the cab idling in 100 plus degree weather. No need to change anything else. The cost of R-134 here is almost the same as R-12 anymore (which can be found at swapmeets, CL, and eBay)
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
