Calling all airride guys!!! I need some advice
Hey guys I recently bagged my '70 stepper and I love the ride, stance and everything else that comes with bagging a truck ... but I ran into a problem. I just noticed that my front bags are sitting on the LCA's at ride height. Any advice on how I can fix this other than tubular lower control arms or cupping the ones I have? I did a lot of research before I bagged the truck and didn't think I would run into this issue so any help is appreciated. Thanks in advance.
Specs: Front: 5 lug disc upfront 2.5" DJM spindles stock Lower and Upper Control arms upper bag plate and 2" cup on bags removed bump stops Dominator 2600 15" steel wheels 225/70 tires all the way around Rear: 5 lug drum 1.5" lowering block Shock relocators CPP Adjustable trac bar (Bent) CPP bolt in C Notch Dominator 2500 bolted directly to the frame and trailing arm
-Mike 1970 C10 Stepside 350/700r4 Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632707 |
Re: Calling all airride guys!!! I need some advice
Truck looks great.
Clearance the arm with a torch and BFH.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
Diggin The SquareLife
Aftermarket or cupped thats it
Squarebody guy
You may be able to switch bags as well, diameter changes between different lift sizes. Can you stuff your rear 2500 series bags up front just to see how it fits?
1988 Chevy R30 Dually Crew-Cab - Build thread Cummins swap + Bagged and Bodied on Semi wheels, work in progress |
Thanks, yeah I could do that
I'm leaning towards the cupped ... if I cupped them would I just mount the bag directly to the LCA or would I just drop it in with the attached cup like it is now? Yeah I thought about doing that and Ill probably try it this weekend. I need to play around with it a little more as far as ride height goes, I'm sure I can raise it a little more and get the clearance but I would still be paranoid.
They mount straight to the arm. Here is a pic of my arms. You can see the mounting holes on the bottom.
Nice progress Mike
Rincon |
