10-06-2016, 03:54 PM | #1 |
Custom Panhard to Frame Mount (with heim)?
Has anyone fabbed or purchased a panhard to frame mount that allows a dropped or adjustable end link height wrt the frame? I have a CPP deluxe bar and I'm thinking of swapping the adjustable end link out with a heim and installing a custom bracket to get the bar more level at ride height.
I've currently got some 2" square tube that I'd planned to use to fab a mount but now I'm thinking there might be something more elegant/strong available on the aftermarket.
1968 LWB C20 / AC / Wood Bed |
10-06-2016, 03:57 PM | #2 |
67-72 parts collector,…
Re: Custom Panhard to Frame Mount (with heim)?
Check with Porterbuilt www.pbfab.com or No Limit engineering www.nolimitengineering.com
10-06-2016, 05:52 PM | #3 |
These are for my watt's link but you get the idea.
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
10-06-2016, 06:15 PM | #4 |
That looks pretty cool, how thick is the steel you used there?
pbfab and nolimit don't have just the brackets listed, and pbfab doesn't even have pics of most of their products so it's impossible to tell what I'd be getting anyway.
10-06-2016, 06:17 PM | #5 |
3/16''
10-06-2016, 06:52 PM | #6 |
10-06-2016, 08:49 PM | #7 | |
I was initially thinking that I could mount some tube where the original mounts and then weld to that a section that drops down, kind of like an upside-down "L". If I do that then I could use the provided poly bushing because the tube would be at the right angle. The tube I got is 1/8" wall so now I'm worried that it wouldn't be beefy enough... and I have no idea how to calculate the required bracket strength
