Old 10-08-2016, 06:27 PM   #1
RestoreAmerica
Top end 5.3 please advise
Hello,
I am a 67-72 Die Hard.
I recently picked up a 2000 Yukon with a 5.3 and posted in that forum.
Very little response or activity. Obviously a gear head is a gear head. I am just looking for input.
Here is what I posted.
Hello,
I acquired this vehicle and it appear to be worth fixing.
Bad head or gasket. I just ordered a set of remanufactured heads.
While I have this torn apart, what else should I do to the motor.
Vehicle had noisy lifters but also had bad head gasket or cracked head.
I don't want to spend more than needed but don't want to tear it apart in 6 months to replace something I could easily replace now.
I have not gotten the heads off yet. Almost there. I decided better just purchase heads for $300 than to just put gaskets on the old ones. These are the head I purchased http://www.ebay.com/itm/201358045312...%3AMEBIDX%3AIT
Would you replace the lifters or just clean them?
Any advice is appreciated.
Thank you!!
RestoreAmerica is offline   Reply With Quote
Old 10-08-2016, 07:52 PM   #2
indymachinist
Re: Top end 5.3 please advise
Replace lifters and lifter trays.
-Curt
My 1968 Chevy shortbed stepside build
indymachinist is offline   Reply With Quote
Old 10-08-2016, 07:58 PM   #3
RestoreAmerica
What about the knock sensors?
Old 10-08-2016, 09:25 PM   #4
Dustytrix
You can get to the knock sensors easy when the go bad. I would leave them alone until then.
Dustytrix is offline   Reply With Quote
Old 10-08-2016, 09:47 PM   #5
What's a knock sensor?
Have you tried your question in the LS swap forum? It may be for swaps but that is what you have and at least that is a place that is related to LS engines. Lots of action here, but it is for topics specific to 67-72 trucks
Old 10-09-2016, 06:08 AM   #6
LeesTruk
The knock sensors do not live in an air tight environment and are susceptible to water intrusion and do corrode. When you pull the intake off, take a look at them and then decide. Change the knock sensor harness as well, if the sensors are corroded. The parts are readily available at most parts stores, and not cost prohibitive. Most likely, the sensor seals will have hardened and should be replaced if you pull the sensors
If you need a hand, I live just up the road in Manchester. Shoot me a PM if you need assistence
LeesTruk is offline   Reply With Quote
Old 10-09-2016, 07:43 AM   #7
RestoreAmerica
I purchased lifters and trays, push rods, knock sensor, and the wiring harness that goes with knock sensor.
Would anyone consider soaking the intake and TBI in kerosene, diesel, or some other type of solution to clean it?
Old 10-09-2016, 05:11 PM   #8
Big Port Jimmy 6
Addicted to Rust
Big Port Jimmy 6's Avatar
I immersed mine in dawn dish detergent and hot water in a trash can. Followed that with a rinse and purple power and it was clean.
Current trucks:
(48 GMC100 320 inliner) Gone
(48 Suburban in pieces) Sold
87 GMC CCSB 5.3 4l60E Daily Driver
ECTA National record holder XO/PP
We never really grow up, we just learn how to act in public.
Big Port Jimmy 6 is offline   Reply With Quote
Old 10-09-2016, 07:11 PM   #9
RestoreAmerica
The entire manifold with fuel injectors and everything?
Old 10-09-2016, 07:54 PM   #10
Willie Makeit
Willie Makeit's Avatar
bare intake - purple power and hot water. clean as a whistle.
Willie Makeit is offline   Reply With Quote
