Inner roof differences between 60-63 and 64-66
I'm working on a 62 cab at the moment and need the inner panel around the windshield area.
I see they make for the 64-66 cabs but not for the 60-63. Is there that much of a difference at the roof between the model years? Thanks in advance!
1962 Chevy C10 Short Fleet My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=692962 |
Re: Inner roof differences between 60-63 and 64-66
If you're speaking of the metal that meets the windshield, then it would change in '64 when they went from the '60-63 wrap around glass to the 64-66 flat glass.
I may have the piece you want up in the barn. I have the roof I cut off of a '62. Send me a PM if you're interested. |
1961 crewcab
it changes where the roof post is. all the rest is the same.
if you look at my crew cab build you can see where I used a 66 inner panel on my 61. http://67-72chevytrucks.com/vboard/s...=646830&page=9 posts 201-203
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
Thanks!
![]() ![]() Join Date: Apr 2012
If your talking about the outer , visor like , section over the windshield its the same from 1960-1966 GM Part number 3833985 . Fits BOTH windshield styles. If you mean the inner roof , above your head as your sitting in the truck , they are 1960-1963 and 1964-1966
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
has anyone on here made this repair? any advice?
