Old 10-19-2016, 09:38 PM   #1
loom34432
loom34432's Avatar
Polishing the grill
Just out of curiosity how did GM polish the grills when new in 72? I'm polishing mine now, starting with 400 grit paper then 600 grit then 1000 & 2000. I don't have pictures yet, I'll post some when I get finished. Boy this sure is taking a long time to finish, starting to feel like I bit off more than I can chew!! Slow and laborious. I'll get there though.
72 C10 350/TH350
loom34432 is offline   Reply With Quote
Old 10-19-2016, 11:47 PM   #2
FirstOwner69
FirstOwner69's Avatar
Re: Polishing the grill
GM did not polish the Chevy grilles. They were anodized. If you polishing yours, did you remove the anodizing first?
FirstOwner69 is offline   Reply With Quote
Old 10-19-2016, 11:58 PM   #3
cornerstone
cornerstone's Avatar
Please post pics of your results because Im interested in trying this on my original after i work out one dent. My buddy told my it couldnt be done because it was anodized.
cornerstone is offline   Reply With Quote
Old 10-20-2016, 12:25 AM   #4
FirstOwner69
There are numerous YouTube videos showing how to remove anodizing. Search YouTube for "removing anodizing from aluminum". Most say to use liquid drain cleaner containing sodium hydroxide (lye).
Old 10-20-2016, 08:38 AM   #5
hewittca
hewittca's Avatar
I did this on my 1980 Malibu. Different vehicle, but same process for polishing anodized aluminum. To make mine even worse, the trim had been painted with etching primer first. The primer combined with the anodizing was a nightmare to remove, but I used the same process as you except for an additional step before and after. My before step was using drain cleaner to help strip the anodizing. My after step was polishing by hand with a metal polish because even after the 2000, the trim is going to look very dull. The trim looked like chrome after it was polished though, so it was worth it. It did require the occasional quick repolishing, however, since there was no protection for the bare aluminum that does like to oxidize.
Builds: Green Gus the 68 C10 | Bluey the 72 1500 | Lowly the 70 C10
Instagram: @dr.hewitt
C10 Concept/Development Photos: Master Thread
hewittca is offline   Reply With Quote
Old 10-20-2016, 10:46 AM   #6
ForrestHead
I'm a welder by trade, and I would caution anyone removing the anodizing layer. Aluminum is in a constant state of decay, and aluminum oxide is as hard as granite. But that being said, I imagine yall are like me and are gonna do what you want anyway. When welding on aluminum livestock trailers, we use Easy Off oven cleaner, works great to clean aluminum, I've sprayed it on my grill before and it makes it pop for sure. It should maintain the shine after all your work.
ForrestHead is offline   Reply With Quote
Old 10-20-2016, 10:57 AM   #7
DT1
DT1's Avatar
I stripped the anodizing with Sodium Hydroxide and water. The active ingredient in Easy off is the same. A pedestal mounted buffer or grinder with a buffing pad is way faster than sand paper. I cut and stacked three 6 inch disks made out of a red Scotch-Brite and buffed all of the scratches out. Then I used cutting compound with a Denim wheel to get the luster back and followed with a cotton wheel with jewelers rouge. When finished, apply a coat of automotive clear cote.
DT1 is offline   Reply With Quote
Old 10-20-2016, 12:39 PM   #8
In The Ten Ring
Nice, let us know how well that clear coat holds up, I'd like to do the same for my truck.
In The Ten Ring is offline   Reply With Quote
Old 10-20-2016, 04:14 PM   #9
DT1
DT1's Avatar
I did this over 6 years ago and to my surprise it's still looks this good.
Disclaimer: Garaged every night.
Old 10-20-2016, 09:08 PM   #10
loom34432
loom34432's Avatar
Hey thanks everyone for the replies. Yes I did remove the anodize coating. I'm having to polish the old fashioned way- elbow grease. I don't have a buffer to use. Good news is I'm halfway finished with the 400 grit.
72 C10 350/TH350
Old 10-21-2016, 10:52 AM   #11
n33k0
That looks great! Anyone have any idea how this would hold up on a DD truck that doesn't get garaged?
Nick
1972 Chevrolet C10 Stepside
n33k0 is offline   Reply With Quote
Old 10-21-2016, 10:54 AM   #12
DT1
DT1's Avatar
Don't really know but if the clear coat starts to degrade with time and it will, just strip it off and re-coat.
Old 10-20-2016, 12:40 PM   #13
71meangreenc10
Its a Truck Thing......
71meangreenc10's Avatar
Very nice!!!
Smitty
71 C10 283/3SPD Full Resto
71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599
70 C10 Suburban Former military GSA truck.
72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378
72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110
68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head
71 C30 Wrecker
71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck
68 GMC Long Stepside. They keep following me home
69 C30 Former Motor Home, Flat Bed time
70 G20 Red-E-Kamp Conversion "I'm your Boogy Van"
71meangreenc10 is offline   Reply With Quote
Old 10-20-2016, 10:45 PM   #14
custom10nut
custom10nut's Avatar
Following.
custom10nut is offline   Reply With Quote
Old 10-21-2016, 05:47 AM   #15
tristan
My 1971 GMC grill surround came back from the plater yesterday. It took months to find someone who would tackle aluminum AND who had a tank big enough to handle a part this large. Once you get past those not inconsiderable obstacles, then you send in a large check and wait. And wait. And wait some more. However, the end product is spectacular (although upside down in the picture).
tristan is offline   Reply With Quote
Old 10-21-2016, 09:07 AM   #16
DT1
DT1's Avatar
It looks great! Trying to find a plater that can do it and not damage it in the process is a problem.
Nice Stang. 68?
Old 10-21-2016, 12:32 PM   #17
davepl
davepl's Avatar
Ah yes... GMC chrome. Expensive to restore, but easier to maintain. Once you get the anodizing off the Chevrolet grill it's going to be a weekly chore to keep it polished. I'd recommend a coating of Zoops or similar product to reduce the rate of oxidation.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 10-21-2016, 04:59 PM   #18
In The Ten Ring
Most everything worth having is expensive. Even our bodies take a lot of work to keep running right and lasting a long time.
Old 10-22-2016, 05:01 AM   #19
un4gvn!
un4gvn!'s Avatar
Tristan, who did your grille? I'm from Latrobe, east of Pittsburgh.
un4gvn! is offline   Reply With Quote
Old 10-21-2016, 10:29 PM   #20
kelsfine69
18 Till I Die
kelsfine69's Avatar
Gmc grills are not aluminum, they are steel and can be re-chromed
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 10-22-2016, 04:45 AM   #21
In The Ten Ring
I have always preferred the look of the Chevy grill over the GMC but if the GMC grill is steel, that changes things a bit for a guy like me.
Old 10-22-2016, 06:03 AM   #22
tristan
Advance Chrome in Erie, PA. My resto shop told me it was aluminum but maybe they were thinking of the more commonly seen Chevy grilles.
