Old 10-20-2016, 03:54 PM   #1
Steven37
Carrier bearing
I have a 1974 chevy pickup and I obviously need a new carrier bearing or support bearing.. Not sure what the difference is.. But I am sure which one to pick.. It is my daily so I cant just take it apart and have it un drivable. I'm not too familiar with this kind of stuff. https://www.summitracing.com/parts/tmk-hb88508a I found this item. Will this item be fine?
Steven37 is offline   Reply With Quote
Old 10-20-2016, 05:18 PM   #2
Gmc.guy
Gmc.guy's Avatar
Re: Carrier bearing
You should be able to get the same one at a local parts store for around the same price. I'd fix it before driving too much, if it comes apart it will cause lots of damage
-Cody
Gmc.guy is offline   Reply With Quote
Old 10-20-2016, 05:20 PM   #3
Gmc.guy
Gmc.guy's Avatar
Re: Carrier bearing
It looks shifted out of alignment, but it could be just the picture. I'd check rear suspension and engine/ trans mounts to make sure all is happy
-Cody
Old 10-20-2016, 05:34 PM   #4
Steven37
Re: Carrier bearing
Here it is from the other side.. Still look out of alignment to you?
Old 10-20-2016, 05:38 PM   #5
Steven37
Re: Carrier bearing
Yes I plan on fixing it this weekend. I am ordering a few other parts online and thought i'd just try and find it online but if you guys dont think that part https://www.summitracing.com/parts/tmk-hb88107a will fit than I guess i'll try going to Napa or autozone and finding it
Old 10-20-2016, 06:55 PM   #6
DieselSJ
Re: Carrier bearing
Got mine at Autozone. Mine was a *tight* fit on the driveshaft. I had to find a piece of pipe to drive the new one on.
DieselSJ is offline   Reply With Quote
Old 10-20-2016, 07:19 PM   #7
Steven37
Re: Carrier bearing
How much did you pay for yours?
Old 10-20-2016, 07:22 PM   #8
Steven37
Re: Carrier bearing
http://www.autozone.com/drivetrain/d...61_4959_10434/
Found this cheap one from Autozone that's in stock at my local autozone.. Will it be as good as the $30 one though?
Old 10-20-2016, 07:33 PM   #9
DieselSJ
Re: Carrier bearing
Less than $20.
AZ had a couple different mfg's on the shelf. I ended up with one from National and it was $19. "Lifetime" guarantee.
Make sure you measure your driveshaft. For my '87, there were 2 possible diameters for the inner bearing.
Old 10-20-2016, 08:47 PM   #10
Gmc.guy
Gmc.guy's Avatar
Re: Carrier bearing
Ya it looks ok. I think I was looking front to back, but backwards. I think. Haha. The last one I bought was around 20-30$ at Napa if I remember right
-Cody
Old 10-23-2016, 11:33 PM   #11
barry1982
Re: Carrier bearing
Sometimes these "steady bearings" can be a real pain to remove. I had to carefully use a cutting torch to remove the last one I did. The inner part of the bearing was seized on the driveshaft.
barry1982 is offline   Reply With Quote
