Old 10-21-2016, 04:17 AM   #1
DJ_
battery cut off switch.
I have a question I Just got running my 1972 k10 with a 5.3 ls and right now its my DD but I want to put a kill switch but for now I just want to put a battery cut off switch like the ones that run off the negative wire off the battery but since I have a 5.3 LS EFI do you guys think it will mess up the main computer for the motor?
[ATTACH]Name:  IMG_1358.jpg
Size:  67.3 KB[/ATTACH]
DJ_ is offline   Reply With Quote
Old 10-21-2016, 08:01 AM   #2
JustToxic
JustToxic's Avatar
Re: battery cut off switch.
It shouldn't be an issue, the computer should hold memory when the battery is disconnected. The LS is used in a bunch of racing applications that require the battery shut off switch. We run them on all of our LS engines, I'd recommend one for anyone with a vehicle that might sit for any time. The one I mainly use is the Allstar Performance unit, works great and never had an issue with one.
1967 Chevy C20 to K20 Conversion "Simply Toxic"
http://67-72chevytrucks.com/vboard/s...d.php?t=749409
1971 Chevy C20 Custom Camper LS Swap http://67-72chevytrucks.com/vboard/s...d.php?t=763775
JustToxic is offline   Reply With Quote
Old 10-21-2016, 10:00 AM   #3
DJ_
thanks for the advice! Now I feel better about using one.
Old 10-21-2016, 12:30 PM   #4
davepl
davepl's Avatar
I put an LS3 in a Camaro and it had some parasitic small 1W drain somewhere, so I had to unplug the battery when parked for more than a day or two, and so it always got reset, and it never bothered it.
I don't doubt there are fuel trims and so on that would be handy to have kept, but it learns them again fast enough it seems.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 10-21-2016, 12:39 PM   #5
DJ_
Yeah My fear is that when I park it and hit the switch that when I come back to the truck that the computer will be reset and right now the truck runs good, my tuner tune my truck almost to the max before i have to run bigger injectors, So i don't want to lose the tuner and the truck not to run right.
Old 10-22-2016, 01:22 PM   #6
Rocket3
Rocket3's Avatar
I have seen a disconnect with a by-pass wire for retaining the memory of electronics,but I don't remember where. Maybe google could help?
David
Rocket3 is offline   Reply With Quote
Old 10-22-2016, 06:49 PM   #7
seafoam68
seafoam68's Avatar
Way back in my mechanic days, when computers first came out on cars if we changed a battery out, the computer would lose all memory and settings. To combat this, they came out with a simple plug that plugged into the cigar lighter and a 9 volt battery on the other end. This maintained enough juice while the battery was disconnected. Dont know if this might help in your situation but it might if a cut off switch causes problems.
seafoam68 is offline   Reply With Quote
Old 10-23-2016, 01:22 AM   #8
57taskforce
All about them K’s
57taskforce's Avatar
Loss of battery voltage won't erase your tune.
Tyler
57taskforce is online now   Reply With Quote
