10-22-2016, 12:03 PM | #1 |
Brake light problems
So i have both blinkers working both tail lights work when lights are on but i only have the passenger side brake light working and the driver side will not work, just re did the wiring ao all the connections should be fine and ive tried installing multiple grounds with no luck any ideas??
10-22-2016, 12:17 PM | #2 | |
Re: Brake light problems
10-22-2016, 12:19 PM | #3 |
Okay thank you, how many body to frame grounds do you think there should be on the truck?
10-22-2016, 12:44 PM | #4 | |
1 & 2 Fire wall to Valve Covers (6 cyl only One used) 3rd. Front Pass side inner fender (frame to inner lower fender well) 4th. Under pass door about 1/2 way too middle of door 5th. Pass side at rear tire location area Most are mounted from body panels to frame |
10-22-2016, 12:50 PM | #5 |
Okay thanks bud ill check em out
10-22-2016, 01:12 PM | #6 |
10-22-2016, 01:19 PM | #7 |
Each Light needs to be grounded so look carefully at each lights connections. Being a Electrician I know I can hold any one bare power wire all day long and NOT get shocked, But when you put the ground wire in or hooked up at that point you will get Shocked believe me I know. The ground wire makes a complete circuit.
