10-23-2016, 01:14 PM | #1 |
Mounts for 327 installation in '78 C10
Hello folks. I'm building a 1965, 327 block to install in my 1978 C10 shortbed. Will the stock motor mounts match up to the '78 frame mounts?
Any info will be appreciated. Alex |
10-23-2016, 02:43 PM | #2 |
Re: Mounts for 327 installation in '78 C10
Use the clamshells that came off of the truck, no problem.
10-23-2016, 06:22 PM | #3 |
Thanks Flatbed
10-23-2016, 11:23 PM | #4 |
Hi there, are you using the original 1965 heads? I ran into trouble installing a 1965 283 into my 76 years ago. I installed 350 engine mounts, that was no problem. I did run into problems with the 283 heads did not having the "tapped" holes in the heads to mount my alternator. Also had trouble mounting the P/S pump. The 327 may have the tapped holes, I can't recall.
10-24-2016, 08:26 AM | #5 |
Hi Barry. Yes, that's going to be an issue. No holes in these heads either. The P/S pump mounts to the driver's side motor mount holes, but A/C and alternator will require after-market brackets that use other fastening points.
Alex |
10-24-2016, 09:35 AM | #6 | |
http://www.alangrovecomponents.com/ |
