K5 with 700r4 question
hey guys, thinking of swapping in a 700r4 into my 72 K5. It is bone stock, with the original 350, TH350 trans, NP205 with 3.73 gears. Going with a 2.5 inch lift and 31.7 inch tires...235/85/16's. Can anyone give me experience or opinions on mpg and performance? Thanks in advance
Carpe manana
![]() ![]() Join Date: Dec 2010
Re: K5 with 700r4 question
I've got trucks here with 33" tires and both 700r4 and th350 transmissions (and 4.10 and 3.73 gears respectively). IMO unless you do a lot of highway driving I'd stick with the th350. I'm building a blazer now and plan to keep the th350 even if I swap the 3.07s to 3.73s.
Not too many K5s with all original drive trains.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
#3 | |
Putting an overdrive transmission behind an old school engine wont give you the gas mileage you would expect mainly because the older engines are not designed to run efficiently at 1900 RPM. If you want fuel economy, then you will have to upgrade both the engine as well as the transmission. Your 3.73 gears are a bit low for an overdrive application especially with your tire diameter anyway, so you're looking at a big expense for everything to run nicely together.
For comparison sake, I have a 5.3 with a 4L60E and 4:10 gears turning 33" tall tires. I get a true 25 MPG (imp) which is equal to 21 MPG US. Unless you're willing to do a complete package, don't waste your time.IMHO |
I have a 383/700r4
I like the combo, runs nice down the highway at 75mph. It's getting pulled for a ls2/4l70 at a later date
1972 Dark blue, Cst, Highlander |
#6 | |
Same combo here. I used to drive a lot highway miles and it worked well. Now I don't, and would like to try a 4l80 trans. On my best day, I get about 10mpg.
'72 K5, known as 'the Fox.' |
10 MPG ? Wow, that would kill me up here in Canada. Regular gas right now is $4.04 per US gallon and is going up in the new year.
![]() Join Date: Aug 2014
Hemi 43 what adaptor did you use on your trans to transfer case?
![]() Join Date: Jun 2004
I put a crate 350 in my 2 wd with a 700R4. Pain in the backside, no advantage and cost a ton of money. Wish I'd kept the 350 trans. Cheaper - better.
4oldcars Driving: 1971 Jimmy w/68 Chev front clip, 1953 Bel Air 2 dr hdtp, 1996 Roadmaster wagon, 2000 Eldorado The ones I let go: 1931 2 dr sedan, 1935 pick up, 1938 2 dr sedan, 1962 SS 454, 1963 409 wagon, 1970 short bed, 1972 short bed, 1972 sub, 1976 short bed, 1986 long bed, 03 short bed |
![]() Join Date: Jun 2014
Its all about the smiles per gallon. No one buys a brick on wheels with a V8 for Miles per gallon
1970 1/2 ton 4x4 4spd Suburban 1972 K10 350/700R/205/ Sniper EFI Daily Driver Sold 1971 K5 on 35s Traded 1972 K5 3/4 ton PROJECT Sold |
agreed....too much for an occasional driver.
No longer have my K5 but I drive it's big brother K20 Suburban.
I like the 4L60 overdrive. Lower first gear for better take off. Overdrive for less stressed engine. Small increase in fuel economy but having the engine last longer has it's benefit. Quieter in the cabin too. Moving the engine forward isn't a terrible task. Shorten the radiator hoses and lengthen the exhaust pipes.
2WD Jimmy
![]() Join Date: Mar 2005
I dont like the 700r4. Its shifts like a powerglide with an over drive.
