![]() Join Date: Feb 2004
Progress on 46
I am awaiting the grill and windshield frame from powder coat and then will continue the puzzle. The seat is not done either -- taking too long.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T |
Re: Progress on 46
Powder coat did not happen. With fiberglass fenders and an aftermarket grill, I have been adjusting for hood fitment for 3 days and probably will take another day at least on the driver side. Hood will be red.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T Last edited by dennislbrooks; 11-11-2016 at 04:57 PM. Reason: words |
Re: Progress on 46
Nice looking grill...where did you get it? Was the fitment good? I'm finding a ton of em online..just unsure where to buy one..And I'd personally run dually...looks awesome..the cool factor in the duallys is where its at...again, nice job!!
and a few others
Re: Progress on 46
Love it.
Bill ![]() BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
Re: Progress on 46
Choices, if I go with an 87" stepside bed, it will have to be widened and slightly tubbed to get 2 " wider rear fenders to cover the 85" width of the duals.
Headboard and the tailgate can be fabbed, tailgate is the more problem. Not got an exact measurement but somewhere around 10" wider which makes the full running boards a problem also. Could go with the big truck running boards -- I have a pair of them. If I go flatbed it is nearly square with width being about 88" and length from 92" - 96"--have about 10 or so inches overhang of the frame. Any pics out there that could help either way?
Progress on 46 -14 bolt
A 1975 c20 14 bolt FF SRW with 11x2 3/4" brakes is near a perfect fit for a 46 3/4 ton. I plan on duals but singles work also. Duals will require fender work - 5+ inches each side but no tubbing. Awaiting ubolts, spring plates, and shock mounts to finish up.
Re: Progress on 46
Very nice!!!!
I love the look of these old trucks.
53 Chevy Pickup |
#8 | |
![]() Join Date: Jul 2007
Re: Progress on 46 -14 bolt
Re: Progress on 46
On the front I used the 6 to 8 lug adapters which are 2 inches thick. Dually front wheel sits in the front wheel well just right with no rubbing of tire on a left turn. Has 16" radials on the front and drum brakes all the way around. I changed the front axle earlier in a thread to a 57 half ton because of getting drums for a 46 3/4 ton.
Progress on 46
Ok, a little cooler out there today -- about 10 degrees. Kicked on the furnace in the garage and can live with 55 degrees.
I had to change out the 14 bolt srw lugs which were 2 3/4" long. Put in dually lugs which are about 3 1/2" long. Only needed a 1/4" for a full lug nut but got a half inch extra. Windshield, header, wiper, and one piece headliner is in... I do not want to talk about the headliner. On duallies, inside measurement from sidewalls is 49 inches. Tires are 7.50x16's.
Re: Progress on 46
Dennis, where did you get your one piece headliner from. Did it fit properly? I know some of them can be a real biotch.
#12 | |
Re: Progress on 46
1954 GMC on 93 Silverado chassis http://67-72chevytrucks.com/vboard/s...d.php?t=408344 1942 Chevy 1/2 ton Pickup http://67-72chevytrucks.com/vboard/s...d.php?t=429494 R.I.P. TOM SEFFRON 68 FOUR DOOR http://67-72chevytrucks.com/vboard/s...d.php?t=495438 1942 Chevy that ate my brain 70 Chassis https://67-72chevytrucks.com/vboard/...d.php?t=835250 |
Re: Progress on 46
Those are 1 ton 16" wheels from a late 70's C30 dually. I have no problem on tie rod ends. Center link (from 46) threads may need cut further on the RH thread end to achieve a toe of 1/4".
I would use a 1955-59 3/4 ton front axle if you can find one and forget the adapters. Spacers can be used if necessary. Axle still needs shortened same as 6 lug. I missed a chance at one close. Dang http://www.67-72chevytrucks.com/vboa...d.php?t=700070 The truck is at my uncles house but the measurement you want is 5 inches less than a stock 55-59 1/2 ton or 3/4 ton. Believe it or not I do mark all my none year parts with a paint pen for future repairs.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T Last edited by dennislbrooks; 09-12-2020 at 08:52 AM. Reason: words |
Re: Progress on 46 - 1 ton stepside
A truck that wasn't but bed is on - will come back off for paint. I just need someone to send me 20" rear fenders.
#15 |
Re: Progress on 46
Painted both doors this morning. Should be dry to touch in another hour. Will hang them next week. Need the room.
#16 |
More Progress on 46 Door logo
Got one door logo done. Mowrystown Brick and tile in Ohio was in business I think late 30's to early 50's. This was actually one of the trucks - cab was on a ton and a half dump truck.
Not the tractor in the article but here is some info for history buffs.. http://www.highlandcountypress.com/C...ill-/4/22/9462
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T Last edited by dennislbrooks; 06-23-2017 at 12:01 PM. Reason: words |
#17 |
![]() Join Date: May 2007
Re: Progress on 46
wow outstanding!
#18 |
Re: Progress on 46
Hmmm --- I see it is truck #8 below the cowl on the cab --need to make an addition.
#19 |
Re: Progress on 46
Doors installed, awaiting side glass. Will work on and finish hood next.
#20 |
Re: Progress on 46
Hey Dennis! Nice progress. You mentioned you are about to put your side glass in. I was wondering if, and where, you purchased the rubber side sweeps for your glass. I recently bought a pair off ebay from Class Chevy. Unfortunately the fit is terrible. They are way to small for the channels in the door. I was wodering if you may have had better luck with a different vendor.
#21 |
Re: Progress on 46
The horizontal glass wipers are from Jim Carter. But I am not impressed. I have them installed on the outside but may not really be functional as they do not appear to stick out far enough to wipe the glass. Let me know if you do any better.
#22 |
Re: Progress on 46
That looks as if it's going to be an issue with the ones I have as well. The portion of the sweep (barrel) that sits in the holding channel is way to small, thus when you put it in the channel, the sweep portion of the rubber actually sits down in the channel as well moving it to far from the glass. If that makes any sense. I see Steele rubber has a set for 4x the price........ $61. I guess when these vendors say it their parts fit 41-46 what they really mean is it doesn't fit properly, it just falls right in so you can't use it. The Fleecing of America!
#23 |
Re: Progress on 46
I do not remember the wipes fitting so poorly on the 42. I think they came from Chevs of the 40's.
$10.50 a set. May be worth a call to them to ask. p/n 3847051
#24 |
Re: Progress on 46 - side window wipers
I checked on the 42 and it has the same problem and were from Chevs of the 40's so I am going to try to double it with the 2nd one going on top (maybe) and should point upward and out about an 1/8" more. Will let you know. I may not worried to much on the inside as the side channels keep the window from rattling. For now at least. I do not have the inner panels done yet anyway.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T Last edited by dennislbrooks; 07-03-2017 at 10:51 AM. Reason: words |
#25 |
Re: Progress on 46
Dennis, How did you go about fastening the window channel felt ? The ones I took out of my truck were held in with screws. When I ordered new ones from Jim Carter it said they should be glued in place. What kind of glue would be used?
I think I am going to take a chance and order a set of window sweeps from Steele Rubber. Unfortunately a set from Steele is $60, and I have not had good luck with them in the past. The sweeps they sell have a cross section phot that shows the barrrel sidth is 5/32 which is larger then the ones I currently have. I AM SO FED UP WITH THIS CHIT!!!!!!!!!!!!!! |
