66 c10 tail light wiring problems
![]() http://67-72chevytrucks.com/vboard/i...ilies/waah.gif |
Re: 66 c10 tail light wiring problems
I just ran the intermediate one with 4th wire (light green).
Brown to lights on. Green right, Yellow left. At rear wires are black and white(neutral). Before you get crazy check the grounds on taillights. Screws to body inside lights.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
I agree. Check your grounds. I ran a ground strap from the taillight housing to the frame on both the left and right sides. Be sure and scrape away all the grease, oil and paint. Bare metal only.
Even after this, there were issues. Make sure the bulb is properly seated in the socket as that messed me up as well. Just stay after it...you'll get it! Tom
My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=705185 How to Get Audiophile Sound in 60-66 Trucks http://67-72chevytrucks.com/vboard/s...=1#post7236896 Building Your Own Speaker Kick Pods http://http://67-72chevytrucks.com/vboard/showthread.php?t=730495 |
#4 | |
There's a connector on the driver's side (US) at the firewall. You could make sure power's getting through there (you'd need someone to press the brake or a piece of wood to hold the brake pedal down. There's another connector near the rear (my bed doesn't have wood, so it's easier to test).
1964 C10 LWB->SWB, 283->454, SM420->200-4R MECHANIC: "ME" |
![]() Join Date: Aug 2004
There is supposed to be a connector on the DS at the frame rail end.
I would check the bulb socket after you ensure the bed is grounded. I grounded my truck, eng to cab, eng to frame, cab to Gram, bed to frame at front and rear( opposite sides)core support to frame
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
#6 | |
#7 | |
Thanks Rope |
![]() Join Date: Sep 2011
I ran a ground from my battery negative to all the lights in the rear. Did the same in the front, no more lighting problems.
Never drive faster than your Guardian Angel can fly Larry |
#9 | |
Using silicone paste at all the connections including the bulb socket will help as well.
Chevy addict
Also make sure your turn signal lever is in the neutral position
Tags |
1966 c10, need help please, wiring diagram |
