10-09-2003, 06:19 PM | #1 |
t400 with low hump?
I am thinking about swapping out my t350 for a t400. Will a t400 fit in under a low hump cab? What else will i need for this swap? I will be getting the tranny out a 78 chevy truck and was wondering if it would be wise to get the driveline and shift linkage also.
1971 gmc 3/4 ton, 350, t350 |
10-09-2003, 06:47 PM | #2 |
It should fit; I have a suburban with a low hump and th400. I would get the driveline and all you never know what you can use.
70 chev c10 swb fleet 72 grill, sb 400, 2/4 drop. 68 chev c10 swb fleet Early classic 4/6 drop with 4wheel disc brakes 9"rear 67-8 buckets tilt and A/C Classic GM Truck Club of Washington . |
10-09-2003, 07:36 PM | #3 |
.....it will fit no prob....i had one in my last shortbed with a low hump
Ken Lyons, Slippery rock pa 68 short step 327 t10 4 gear 72 2wd blazer project 70 lwb 305/700r driver 78 caprice project 02 cavalier D.D ( hate it!!) |
10-09-2003, 07:50 PM | #4 |
its all about the +6 inches
Teh drive shaft you get with the tranny will be too long, and the rear of it may not be right for your diff. However, it will have the slip yolk that you'll be needing.
10-10-2003, 06:04 PM | #5 |
My C30 came with a THM400 under a low hump, too.
Just as if I knew what I was doin' |
