Hi , Has anyone fitted up a tunnel ram on there truck?
i have a big block in my 63 and distributor fitment is almost impossible,,It had a mallory unilite in it but to remove i had to take of tunnel ram which isnt fun.. im thinking about a small body msd dizzy? Has anyone had an issue with distributor fitment between manifold and firewall.? thanks, Gavin.. |
Moderator
![]() ![]() Join Date: Aug 2011
Re: Tunnel ram on trucks...
You'll LOVE the way it drives - NOT.
There's a reason.
60-66 Nut
Even f your big block is in the original small block location, there should be plenty of room for a standard cap distributor. There should be room for a HEI distributor. However with a tunnel ram, that does complicate the installation and removal. Can you remove just the top of the manifold to gain easier access? Maybe if you post a picture, we can see better what your issue is. I will have to say though, that not many people run tunnel rams in these trucks.
![]() as you can see i cant remove dist without ram coming off.. has anyone used the msd small body dist #8507 ? Last edited by USA69Z; 10-29-2016 at 02:11 AM. |
60-66 Nut
OK, yes I do see now. I did not realize that you had a Victor Ram.
Yes , i cant remove dizzy without removing the tunnel ram, a real pita ! maybe time to go to a more sedate setup.. It runs great though !
mmm great idea..
