Old 10-29-2016, 04:22 PM   #1
83GMCK2500
Paging DirtyLarry, roommate bought an 8.1 Yukon XL
Also, anyone else with vast 8.1 experience. I searched the limited 8.1 threads we have around here and I didn't quite have all my questions answered, would appreciate your input on maintenance items, recommended service.
My roommate (Ted) has a '97 K2500 EC/LB 454/NV-4500 truck that he uses to tow his TT around in the summer on camping trips. Recent addition to the family (up to 4 now) dictated it was time to find a larger tow vehicle. Found:
2001 GMC Yukon XL 2500 4x4, 8.1L, 4.10/G80, 192k miles (Ted subscribes to the "no replacement for displacement" theory)
I went and looked at it with him, usual seat wear, couple small dents, overall really clean and well taken care of. Hadn't been started in weeks (supposedly) and it was cold when he started it up while I had my head underhood. There was the slightest valvetrain noise that almost totally clears up after short while. I crawled under it and there is a loose heat shield, that's it. The rear axle seals are clean, pinion and ends; transfer case outputs are clean; front axle is clean...it's really quite impressive. The only wet spots are steering lines and engine oil cooler lines. The trans fluid still had enough red to it and didn't have any unpleasant odor, I know the 80/85E is far more robust than the 60/65E found in 1500s.
The person Ted bought it from has had it since 163k miles, in that time he's done engine oil changes, a radio install, and the driver door window regulator. That's all he could remember.
Other observations: once it's warm it has a random miss, brake fluid is black, power steering fluid is dark, under very light load and a medium coast the rear end has a slight whine.
What we've got on the list so far:
- Plugs & wires (already ordered oem delco sets for both)
- Seafoam the intake and half can in the fuel tank. It's due for an oil change, do that after seafoam.
- Check/replace air filter, replace fuel filter, check/replace cabin filter
- Trans filter and fluid (not full flush, just the qty required to do filter).
- Transfer case oil change
- Front and rear diff oil change
- Would like to talk him into power steering fluid flush and brake fluid flush.
In the past I've had good results putting ~1/3-1/2 can of seafoam in the engine oil when it's warm, running it a short while and then doing an oil change. I've also read where some people use ATF and the detergents in there accomplish the same thing only more gently. Yay/nay/waste? If the tuneup doesn't clear up the random missfire there is a good injector service shop in the area that disassembles, ultrasonically cleans, puts new screens, seals, etc as part of a complete injector service.
Anything we haven't though of? The two 8.1s my dad had were 1) half the miles and 2) ordered brand new. This is the first higher mile one I've been around, but I've got 305k on my '96 now so not unfamiliar with high mile big blocks. What do you recommend for engine oil, brand/weight? I run Shell Rotella T 10W-30 in my 454. Ted hasn't had this one long enough to determine how much it uses at what interval, but I warned him that is a "feature" of the 8.1.
Thank you for any advice you might have, onto the pics.
P.S. The last L29/L18 advice you imparted upon me was here: Post 27 and just wanted to update that I found brand new L21 valve covers and the correct ECM bracket to retain the 12200411 ECM under my GMT-400 hood. The one found in 2002 3500HD chassis-cabs...had to special order them, so I ordered 10 and will be selling the extra for the increasingly common 411 ECM swap.
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 12-07-2016, 04:21 PM   #2
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
Re: Paging DirtyLarry, roommate bought an 8.1 Yukon XL
Sorry man, I don’t get here much anymore unless someone calls me by pushing a subscribed thread to the top. Also, had to turn off the PM feature as way too much BS was coming through.
That looks pretty clean for the age and miles. I wouldn’t worry much about the valvetrain noise as they all seem to do it for the first 30 seconds to a minute after they are started cold. My 2001 has done that since new. The K10 and Suburban also do it although some of the noise in mine kinda sounds like the clutch release bearing rattling for a few seconds
How did the tune up and Seafoam go? The warm miss was probably just tune up time, time for injectors or a possible vacuum leak. If it needs injectors there is a company selling new take off 8.1L fuel rails w/injectors for $149 on Fleabay. The rails were removed from Schwan’s Foods trucks years ago when they were retrofitted to run on propane. Granted, they have been on the shelf a long time since the engines were new but still can’t beat the price. I have a set of those on my Polar Bear. Changing injectors on an 8.1L is a quick 20 minute job.
Being it is a high mileage 2001, it surely has to have a newer Crank Sensor in it but it might be worth throwing a fresh one in just so your buddy knows the age of it. Don’t settle on an aftermarket sensor. Get the real deal…. 12575172. The bad news is if it ever needs a cam sensor he will be needing to replace the cam sprocket and timing cover in order to upgrade to the later design cam sensor. The early design has been discontinued. It might be worth updating the cam sensor a head of time before it breaks down at the worst time then have to locate all the parts. Raylar has good info on the cam sensor dealeo. I need to do this to my 2001 Silvy too.
That is cool L21 valve covers and ECM bracket! Good score!
DirtyLarry is offline   Reply With Quote
Old 12-07-2016, 05:15 PM   #3
83GMCK2500
No worries, as I've had to clutter your threads with side questions before I figured I'd just wait until you were active to catch you. An acquaintance of mine added me to the 8.1 facebook swap group, seen a few of your posts there.
Seafoam and oil change happened soonest, ran noticeably smoother at idle. Plugs & wires came by the next weekend, did those during a halftime and went for a drive...MUCH better. Almost completely cleared up any misses at idle.
I took a few pics of the plugs that came out. Looks like the poor thing had cheaaaaap fuel in it. If that engine is numbered classically, what do you think of #7 & #2? (box is labeled Front for ref.) Dirty injector?
It's been over Snoqualmie Pass in WA now with their TT, towed it great, they loved the room and the power. I'll forward the info about Cam & Crank sensors. It does have an oil leak on the passenger side of the engine, haven't crawled under with a light yet. I would say mid-rear of engine.
Devin
New Daily, the '96
Old 12-07-2016, 06:04 PM   #4
DirtyLarry
DirtyLarry's Avatar
Not only cheap fuel but looks like some cheap spark plugs too. I prefer to run only Platinum tip plugs in the later engines. As odd as it sounds because they have white deposits on them, they all look to have some oil fouling although 2 and 7 do look like fuel build up on them like leaky injectors. 8.1s love oil, especially the earlier ones.
