Old 10-30-2016, 01:42 AM   #1
dooce
Blazer buckets into pickup
I've got a couple of sets of blazer low back buckets but cant seem to find any definite answers on how to go about fitting them in a bench seat pickup. My truck is a 76, anyone know of a link or does someone make brackets?
1976 Chevy 1/2T 2wd SWB
327/Saginaw 4spd 3.73:1
LQ4 6.0/T56 Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=772071
LFSalleeII@gmail.com
dooce is offline   Reply With Quote
Old 10-30-2016, 08:26 AM   #2
bhc41051
bhc41051's Avatar
Re: Blazer buckets into pickup
The military M1010 ambulances had factory buckets, might be a good souce for the mounting brackets. http://www.73-87.com/7387garage/inte...ry_buckets.htm
bhc41051 is offline   Reply With Quote
Old 10-30-2016, 09:20 AM   #3
bbbc10
Diggin The SquareLife
Suburban brackets
bbbc10 is offline   Reply With Quote
Old 10-30-2016, 11:40 AM   #4
dooce
That link mentions suburban brackets are different. Will all suburban brackets work, even the late model ones that look nothing like these seats?
Old 10-30-2016, 06:22 PM   #5
1774btcrew
1774btcrew's Avatar
He is suggesting using the weld in inner Suburban brackets to mount them to the floor.
AZPartsLocators on Instagram
1972 Cheyenne Super Short Bed big block "Blackie"
1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog"
1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck.
1774btcrew is offline   Reply With Quote
Old 10-30-2016, 06:48 PM   #6
dooce
OK, so the blazer seat rails will bolt to the suburban floor brackets welded to a pickup cab?
Old 10-31-2016, 09:03 AM   #7
Breeze454
Breeze454's Avatar
The only part of the Suburban/Blazer bracket that will work in a reg cab are the front mounts, the floors are different at the rear between the two.
I recently put Porsche buckets in my 77 and ordered seat mounts from WedgeBrackets.com. A bit pricey, but the fit was damn near perfect. The only hole I had to drill was the inner front, the inner rear bolts up to the seat belt mount, outside holes line up with the factory ones.
I' sure with some fab work you could mate some sub brackets with some donor pieces from a bench to make it work, if you want to get in to all of that.
Breeze454 is offline   Reply With Quote
Old 10-31-2016, 10:30 AM   #8
N2TRUX
Happy to be here
N2TRUX's Avatar
From what I know the Suburban brackets will work. The rear has to be bent to fit, and I believe a couple of holes drilled. Contact Capt Kaos for complete details on how its done.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 11-01-2016, 10:36 AM   #9
MalibuSSwagon
I put Suburban buckets in my 86, just had to bend the rear ear of the tracks upward to match the floorpan in the pickup, and drill the inner rear hole. Mounted the floor bracket on the inner front and good to go.
MalibuSSwagon is offline   Reply With Quote
Old 11-01-2016, 10:38 AM   #10
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
You need suburban bucket seat brackets AND the inner front mount from the Suburban floor. None of the Blazer brackets work. Just unbolt them and bolt the Suburban brackets to the seat. The rear seat mounts have to be bent to match the floor angle of the truck.
There are also aftermarket brackets that work too.
For more detailed info on bucket seats look here:
http://forum.73-87chevytrucks.com/sm...?topic=28744.0
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Last edited by Captkaos; 11-01-2016 at 11:05 AM. Reason: Added link to bucket article I wrote
Old 11-02-2016, 02:33 PM   #11
dooce
Found these brackets in a suburban with buckets with armrests today in the junkyard. They look different than all the other brackets I've seen pictures of, can anyone verify that they will work?
Old 11-02-2016, 03:09 PM   #12
Captkaos
Captkaos's Avatar
Yep, those are what you want. All the suburbans with buckets will have those.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
