10-30-2016, 12:06 PM | #1 |
Looking for Serpentine Belt options
Getting ready to build a 350 for a truck. Don't have any pulleys or brackets to start with, so figured I would just do a serpentine belt drive. This truck will have a Vintage Air IV kit, so I will need A/C brackets.
Anyone have any ideas to help me out? Thanks! Jimmy
Jimmy Hoelzel |
10-30-2016, 12:10 PM | #2 |
Re: Looking for Serpentine Belt options
If this was my problem, I'd be going to a wrecking yard, and grabbing the complete bracket, tensioner, alternator, etc from a later model truck with the 350. The only thing I'd worry about is that the block and heads you use need the mounting holes for the serpentine brackets.
Rick -69 GMC 910 Long Box, 350 -98 Chev Silverado 1500, 350 Vortec 4L60e -08 Mustang GT Convertible |
10-30-2016, 12:21 PM | #3 |
That's exactly what I did. Got all the pulleys, tensioner and power steering pump for $75.00.
10-30-2016, 12:39 PM | #4 | |
Then you have the GMPP kits that are basically a factory unit, sold as one kit then there is the of wrecking yard take offs. The biggest concern with any of these is getting a compressor/bracket that works with the vintage air. VA recommends using sanden compressors, which are generally what you will find on any of the aftermarket billet kits. Some of the factory GM brackets use "pancake" style compressors typically found on the later g body cars and corvette's. I have used these compressors with vintage air kits and had success as well. |
10-30-2016, 02:11 PM | #5 | |
motor exploder
I'm using the VA Gen IV, but after I rounded up the parts I didn't care for the looks of the factory style setup, so I ended up getting one of the March Pro Track systems. Functionally, the factory brackets work fine, I just wanted a different look. a couple of threads about it: http://67-72chevytrucks.com/vboard/s...d.php?t=585944 http://67-72chevytrucks.com/vboard/s...d.php?t=413940
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
10-30-2016, 02:11 PM | #6 |
Bad thing about junk yards around here is that you get what they pull. You stop by and tell them what you want, and they pull it off the cars. They don't allow no one in the yard.
Jimmy Hoelzel |
