Old 10-09-2003, 10:03 PM   #1
zork
air compressor problem
I need some advice I have a 5hp single stage 60gal up right that was made in 82. The motor is junk pumps oil into tank. The tank is in nice shape.
I just bought a used 5hp dual stage 60 gal lay down type.The thing runs good but the tank is cracked down by the leg supports.
Someone tried to weld it unsucessfully.
Should I try to weld it again?
Should I just rig it to my stand up tank?
Both tanks were made by Buckeye Boiler co. Dayton Oh.
Tags on tanks wp200 temp450 heads140 shell154
wp150 temp450 heads104 shell115
Thanks Zork
zork is offline   Reply With Quote
Old 10-10-2003, 06:48 AM   #2
JimKshortstep4x4
Smile
I would not attempt to weld the tank, especially since the crack is down low where corrosion is very likely.
Jim
Old 10-10-2003, 07:17 AM   #3
VTKidder
I second that.
For my $$, I'd poke around and look for another motor, maybe ebay (not harbor freight ). They're pretty much a universal type motor with a couple different variations.
If you're unsuccessful, might wanna look into a new compressor. I would trust a welded tank about as far as I could throw it.
VTKidder is offline   Reply With Quote
Old 10-10-2003, 09:16 AM   #4
truckster
truckster's Avatar
I would never trust a rewelded tank. You're playing with your life there.
You can mount the good compressor on the good tank.
Something else to consider- if there's oil in the tank, it's the compressor head, not the motor. You can rebuild a compressor a lot easier than you can rebuild a small block. Your local compressor supply house should have the parts or be able to get them.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 10-10-2003, 09:38 AM   #5
jef5150
Inline 69
jef5150's Avatar
ZORK-----wow,connelsville,Pa,small f'n world.my mom grew up there till she got married to my dad,he grew up in uniontown,his dad was a doctor in uniontown,,,,,oh ya, id dump the tank,who knows there might be more stress cracks you cant see,. ........jeff
jef5150 is offline   Reply With Quote
Old 10-10-2003, 10:16 AM   #6
hgs_notes
GEARHEAD
hgs_notes's Avatar
I'm a National Board commissioned Boiler and Pressure Vessel inspector. I just spent the last three years as a third party ASME inspector at the Coleman-Powermate air compressor plant. I now work as an inspector for the state of Minnesota.
Trash the cracked tank. Horizontal tanks typically rust all along the bottom and eventually fail. If its cracked now, it's total junk. The 1982 tank may be alright. If you lay the tank on it's side and remove the drain plug, use a mirror and flashlight to look around the bottom end. If it looks pretty clean and rust free, it should last for years. If it's corroding at all, I'd probably junk it. They are usually only .096" to begin with.
What I see quite often is somebody running the compressor discharge line from a compressor on a bad tank to another tank sitting along side it. Most people don't want to waste that much space. The easiest and cheapest fix would be to cut the compressor/moter base from the horizontal tank and weld it right to the top of your verticle tank. Just don't weld to the tank itself. The problem here is that the larger pump and moter of the two stage may me bore than the verticle tanks base can handle, which would cause cracking where the base meets the tank or on the feet.
Overall, your probably best off buying a new compressor. A two stage is great, but usually way more than a regular garage needs. You can buy compressor pumps through harbor freight also.
Good luck, and don't risk yourself, your garage buddies, your neighbors and family for a few dollars.
Mike
hgs_notes is offline   Reply With Quote
Old 10-10-2003, 10:21 AM   #7
hgs_notes
GEARHEAD
hgs_notes's Avatar
One more thing, I'm assuming the 200 psi tank is the horizontal and the 150 psi is the verticle. If you use the two stage pump on the 150 psi tank, it will likely overpressure it. It won't blow up or anything, but the relief valve will lift and your two stage pump may run until it locks up tight. Not recommended.
Old 10-10-2003, 10:50 AM   #8
lux hauler
Psycho-billy Member
lux hauler's Avatar
My compressor (that I got a little over a year ago) has a Buckeye sticker on the front of it. I got the compressor from Eaton Compressor & Fabrication. They're located just outside of Dayton. If there are parts that you need, you might try contacting them. They might have the parts or info that you need.
'72 C-10
350 w/Lunati Voodoo cam (207*/213*, .437/.454), Performer intake, 625 Road Demon Jr. and Hooker headers.
Support your community, support yourself. Buy local, buy American (or Canadian).
lux hauler is offline   Reply With Quote
Old 10-10-2003, 11:38 AM   #9
oldsub86
"If you use the two stage pump on the 150 psi tank, it will likely overpressure it. It won't blow up or anything, but the relief valve will lift and your two stage pump may run until it locks up tight. Not recommended."
Just change the cutout pressure so it doesn't pump up so much. I lowered mine to 125# as I don't think I need greater pressure and it doesn't make my compressor work quite so hard.
1968 Chevy - 292 with a powerglide
oldsub86 is offline   Reply With Quote
Old 10-10-2003, 03:35 PM   #10
zork
Thanks for the input. I am trashing the bad tank. Going to use switch from 150 tank that way I will not over pressure the tank and the 5hp dual stage will not work as hard.
Thanks again Zork
