10-31-2016, 09:21 AM | #1 |
removing a lift with BASIC tools.
Okay so im tired of having to climb in my truck to do repairs, and was wondering how to remove the rear blocks, with basic tools, and how to make the fromt shackles the right length, again with basic tools. like i got some sockets, a jack, and impact, some pb blaster, and a ratchet, pliers, knives, etc to work with. anyone have any tips?
1994 k1500, Oldredz71(ext shorty 4x4 6 in lift) 1998 S10ZR2 2005 Silverado 2500hd(tow pig) Made in the USA, just like my trucks |
10-31-2016, 12:47 PM | #2 |
Re: removing a lift with BASIC tools.
Well the most basic advice I can give you is:
- Soak everything well in PB. Repeat in a couple of hours. - Don't bother touching it for a week, find something else to do, but soak the bolts every day with PB - After a week it should come apart. If not, try some heat. The key I'm trying to get across is that PB works over time, and sometimes a lot of time! But that approach allowed me to disassemble my truck with hand tools and not have to cut anything, even though it was 45 years together.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
10-31-2016, 01:04 PM | #3 |
Yes easy money. The main tools are good jack stands! Get the frame on stands and load off the axle. You can get the bolts off with a breaker bar. As for the front, I assume you have new spring for front already. But for extended front shackles, you can drill holes up higher and cut off excess. But if you have some type of out of the normal lift post pics. It's a one man job, good jacks and jack stands are the main tool here.
White K20 |
10-31-2016, 07:21 PM | #4 |
I got a set of 6 ton jack stands for my 4x4 conversion project from harbor freight that have worked well and are about 2 foot high, ( a must for lifted rigs). I'm sure several vendors sell the same ones (in a different color). I think they were forty bucks. I jacked the axle up removed the wheels and set it down with the stands under the frame. And I still had plenty of room for a jack under the axle.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
10-31-2016, 07:23 PM | #5 |
I'm a firm believer in grinding the u bolts off and replacing with new.
1982 K10 SWB 1987 V20 - Sold - Doh! |
10-31-2016, 08:20 PM | #6 |
10-31-2016, 09:48 PM | #7 |
How much lift are you looking to have when finished? How high is it now? There some may be some lift in the springs and if it was done right the drive shaft lengths may have been altered as well as the pinon angle depending on how high it is. The front shackles are not hard to find OE style or aftermarket or make your own.
http://www.offroaddesign.com/catalog/hdshackles.htm
10-31-2016, 07:55 PM | #8 |
I was thinking jack the truck yp,put it on jack stands, cut u bolts, put new ones on after removing blocks, but what about the front?
10-31-2016, 10:05 PM | #9 |
It has driveshafts that can telescope. and has about 3-4 in.
10-31-2016, 10:40 PM | #10 |
If you're just tired of climbing in working on the truck, take the tires off and let the rotors/drums sit on 2x blocks. It will be lower than a stock truck with tires on.
11-01-2016, 01:17 AM | #11 |
Good advise on soaking the U bolts. You must clean them first with a wire brush on a drill if you don't the gunk in the threads which is usually 2-3 nut lengths will build up and bind the nuts to the bolts. Clean them up good and then oil em, the impact should take them off. Or cut them since you will probably need new ones without the lift blocks in the rear.
11-01-2016, 06:18 AM | #12 |
I cut u-bolts and soak everything else. When I changed out my original springs on my '72 last year, all the front spring eye bolts and u-bolts threaded off as if the truck was new. I reused the spring eye bolts. I saved the u-bolts.
11-01-2016, 11:38 AM | #13 |
Also it looks like my mother will be driving this truck too (shes 5'0) and i dont want her to have to climb pluss it fits 40's without rubbing, and i want to run like 33/35s or smaller.
