Old 11-02-2016, 10:08 AM   #1
paulkaminskijr
Trailing Arm Crossmember Brackets
So I'm currently doing a long to short bed conversion on my '70 C10 and while I have it apart, I want to get started on the suspension. I'm planning on lowering the truck 6-8 inches. I've seen the anti-squat brackets that relocate the trailing arm up on the crossmember. I'm curious if everything would clear if I removed the stock bracket and just flipped it upside down and bolting it in. Has anyone done this and does it work/clear?
Also if anyone has trailing arms they are trying to sell, one of mine is no bueno.
Thanks in advance.
1970 C10 - SWB (Converted)
2011 Silverado 1500 Ext. Cab
paulkaminskijr is offline   Reply With Quote
Old 11-02-2016, 10:34 AM   #2
bsampson
Re: Trailing Arm Crossmember Brackets
Yep, it's been done. I'm planning to do it myself this winter as I convert my leaf springs to coil springs (and 6" drop). Just remove all the rivets, and bolt it back "upside down".
Here is a discussion on it:
http://67-72chevytrucks.com/vboard/s...d.php?t=452149
There are probably other threads too, that's just the first one I found.
bsampson is offline   Reply With Quote
Old 11-02-2016, 10:52 AM   #3
paulkaminskijr
Right on, thanks man
lowering blocks, rear crossmember, rear suspension, trailing arms
