Old 10-10-2003, 01:25 AM   #1
67 cst swb
67 cst swb's Avatar
WTB... 327 Block
I'm still dreaming of finding a 327 block with V1220YH code on the pass. side front cyl. heads mount surface. I'll probably never find but ???. I gotta ask every once and awhile...for my 67 CST truck. If you have one let me know thanks.
Update:
I am interested in a truck 327 engine that has been cast/built sometime in the Dec 01 thru Dec 20, 1966 timeframe (early 1967 truck built date potentially). So a casting date code of L 01 6 to L 20 6 (this will be on rear pass side of engine block)
After some education from another board member (thank you SS Tim and PICKMUP)
An engine that the front pass cyl head pad is stamped V1220YH or shortly before such date, such as 12-01 to 12-19 would be awesome. As that is the exact code on my Protect-o-Plate for this truck.
What this code means: V = built in Flint, Mich 1220 = Dec 20th 1966 YH = connected to a TH400 engine.
I am not looking for just any old 327 block/engine, as I have one or two already and have access to a few others.
I am kind of believing that finding a V1220YH (or slightly earlier date cast) stamped block may not be as impossible as I originally thought.
Thank you
My Trucks:
1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project
1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver
1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck
1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck
2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White
67 cst swb is offline   Reply With Quote
Old 10-10-2003, 07:25 AM   #2
teeitup
Just like to part out trucks!!
teeitup's Avatar
I got one is this 72 I'm selling but I don't want to sell just the motor, its a 327 with 350 heads, I got the 327 heads. I'll try to see if it has the numbers you are wanting on it. I'm asking $1200 for the whole truck, rebuilt tranny. Motor was bored .30 for the pistons, .10 under on the mains, it was hot tanked. Has a new eldebrock carb on it. Truck runs and drives good. Thanks Randy
67 Chev swb stepside 4x4 283 4 speed SOLD
72 blazer 4x4 4 speed Cheyenne
72 GMC swb 4x4 fleet 4 speed, original paint
1958 Cameo (one of 1405 built, it was my dads)
2020 chevy Apex 4x4 crew cab
1969 Z28 with the 302
1980 chevy swb 4x4
1964 chevell Malibu SS
1976 K20, sold new originally out of my dads chevy dealership
Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure"
teeitup is offline   Reply With Quote
Old 10-10-2003, 01:28 PM   #3
kevhill85
91 SWB 383
kevhill85's Avatar
if u where closer . i have 2 short blocks
96 2dr Tahoe protruning LS1 347/4L60L, PSI harness, body dropped, 4link, 6lug conv, narrowed rearend, Schoenfeld headers, 2600 stall, 317 heads milled .040,
http://photobucket.com/albums/q169/k...ahoe prostreet
kevhill85 is offline   Reply With Quote
Old 10-10-2003, 06:04 PM   #4
teeitup
teeitup's Avatar
Here is what is on my block V0T10YC.
1980 chevy swb 4x4
Old 10-10-2003, 07:00 PM   #5
Class of 69
Class of 69's Avatar
South Dakota to Dallas in 12 hours!!! Just a weekend sprint, if he has what you want!
69 GMC K10 ..some restoration required....still..
Class of 69 is offline   Reply With Quote
Old 10-10-2003, 10:27 PM   #6
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
Wasn't that stamped number in sequence and only came in one actual vehicle? If you are trying to get the correct one for your truck you should be looking for a '67 casting date on or before your build sheet date. That is how we get the muscle cars number matching.
Then when you cut the deck it takes the stamped # off and you just restamp the one you want. The casting # is the one that you can't redo.
An example: I have a '68 327 motor with a date code of C 12 8 (Mar 12, 1968) and a stamped # Vo326YV.
This engine is an original 68 Chev PU 3/4T w/4bbl.
Email: frankeham@comcast.net
Phone: 360-956-7170
PICKMUP is offline   Reply With Quote
Old 10-11-2003, 05:56 AM   #7
kevhill85
91 SWB 383
kevhill85's Avatar
they both came out of 69 camro .
Old 10-11-2003, 05:19 PM   #8
Vince M
Vince M's Avatar
I've got a 68 327 for sale but your about as far away as you can get in the continetal US. Stamping is VII24HM. $400 with recent rebuild. Air Cleaner to pan, fan to flexplate. Also have a correct 68 TH400. $200. Ain't a 67 but nevertheless I thought you might want to know.
68 Chevy CST SWB w/LS1, carb & 700r4. Golden Anniversary clone with a few improvements.
Vince M is offline   Reply With Quote
Old 10-13-2003, 11:30 PM   #9
67 cst swb
67 cst swb's Avatar
Teeitup... Thanks for looking at the #'s on the block
Kevhill85 and Vince M... thanks but I am looking for Dec of 1966 cast blocks
Pickmup... I have questions...
So, the only real reason I'm looking for this V1220YH code is. Its the only factory piece missing from my truck. The Protect-o-plate in my owners manual has the V1220YH code, And now that you have said it your exactly right I've decked every motor I've ever built, (duh)
My Trucks:
Old 10-14-2003, 12:15 AM   #10
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
Date code
Let me answer your Q here. The date code is cast on the top rear of the eng on the upper RH side, by the distributor. The letter is the month: A=Jan, B=Feb, C=Mar, etc. Next is one or two numbers for the day of the month. Last is a single number for the year.
Phone: 360-956-7170
Old 10-14-2003, 12:20 AM   #11
67 cst swb
67 cst swb's Avatar
ok... but?
How do I know, or find out what Date code my truck needs? I've always just built these trucks never even thought of restoring one, just rebuilding... from what (i think) i've learned previously on this board. My "block" was cast on or before 12-20-66 my truck was originally purchased from a dealership in Iowa in Jan. '67 so do I need to find out the "build date" of the truck or ???. And where do i need to look? Or do i just look for a block cast on or before 12-20-66. does it have another stamp somewhere for Flint, Mich. plant Thanks for helping with this Q.
My Trucks:
Old 10-14-2003, 12:45 PM   #12
Breese
327 Shortblock
Bryan, From what I have seen over the years is they (GM), will use a block that was cast-built, up to 6 or 8 months later. They have to use up there stock. The 327 shortblock I have for sale on here is dated C 29 6. (March 29, 1966. The suffix # on the number pad is F0406EA. I will bring this engine to the top of parts board. PM me any questions, or leave a post if you are interested.. Thanks, Rich
Breese is offline   Reply With Quote
Old 10-14-2003, 03:50 PM   #13
67 cst swb
67 cst swb's Avatar
I have a 67 327 block from another p/u. Just don't know what makes it "correct"...
Thanks for everyones help...
My Trucks:
Old 10-14-2003, 04:42 PM   #14
BtnkBndt
Pennyless Fool
BtnkBndt's Avatar
Maybe this will help.
http://www.yearone.com/updatedsingle...gineinfo1.html
BtnkBndt is offline   Reply With Quote
Old 12-31-2014, 04:29 PM   #15
67 cst swb
67 cst swb's Avatar
Re: WTB... 327 Block
OK, so I am reviving this post, all in hopes of finding a engine.
I am again/still searching for a 327 engine out of a 10-20 series truck.
One that the front pass cyl head pad is stamped V1220YH.
This code means: built in Flint, Mich on Dec 20th 1966 connected to a TH400 engine.
I am not looking for any old 327 short block as I have one already and have access to a few others.
I am interested in talking with anyone that has a 10-20 series truck with a 327 in it that was built sometime in the Dec 1966 timeframe, just to get some info from you.
I am kind of believing that finding a V1220YH stamped block may not be impossible.
So... Here we go !!!
My Trucks:
Old 12-31-2014, 05:32 PM   #16
Gary 70 Jimmy
Gary 70 Jimmy's Avatar
I have a 327 out of my 67 chevy c20 but it had a stick shift. I will check the block #. I was saving this motor for a 67 project.
1972 GMC Jimmy 1/2 4X4 4wheel camper
1970 GMC Jimmy 1/2 4X4 350
1969 Chevy Blazer 1/2 4X4 307
1967 chevy LWB 3/4 396
Gary 70 Jimmy is offline   Reply With Quote
Old 12-31-2014, 05:57 PM   #17
jmader
jmader's Avatar
I went through the same search for my 67 about a year ago and ended up finding my block on eBay. I just did a quick search and there are actually quite a few 327 blocks on there. They are usually incorrectly advertised as Corvette motors but if you do some searching I know you could find the YH suffix and possibly even the exact one you're looking for.
1949 Chevy 3100 Five Window
1964 Chevy C10 Lambrecht Auction project
1967 Chevy SWB K10
1967 GMC K15 Project
Build thread-
http://67-72chevytrucks.com/vboard/s...72#post6502772
1968 Chevy Anniversary K10
1991 K5 4" Lift 35's (the wife's toy)
jmader is offline   Reply With Quote
Old 12-31-2014, 11:10 PM   #18
daddymoo2
67 CST SWB: I have a 327 long block with stamp VI228YH and casting date L/8/6. Block casting number 3892657. I have a 1967 built in January. Truck was purchased new in California. Thuck is now in Kentucky. Hope this helps. Thanks Don
daddymoo2 is offline   Reply With Quote
Old 01-02-2015, 12:10 PM   #19
67 cst swb
67 cst swb's Avatar
So, your block is a Dec 28th of 1966 stamping code with a Dec 8th 1966 casting date. So that is approximately a 3 week difference.
And thank you so much for the casting number of 3892657.
The other items I would be curious to know is:
If your engine is all original...
1) what are the head casting numbers and dates?
2)Intake casting numbers and dates?
3)carb number? (I am assuming your will be 7036125 or 7037125)
Oh and are you saying this engine may be for sale?
Thank you so much for the reply.
My Trucks:
Old 01-07-2015, 05:56 PM   #20
67 cst swb
67 cst swb's Avatar
So, I am still searching for a 327 block that was cast in early to mid Dec 1966
My Trucks:
Old 01-07-2015, 10:37 PM   #21
Dustytrix
My brother has a 327 complete fresh rebuild for sale these are the numbers.
T0110HC L/30/6 3903352
Is this the type you are looking for?
Dustytrix is offline   Reply With Quote
Old 01-08-2015, 01:17 PM   #22
67 cst swb
67 cst swb's Avatar
Didn't expect a reply that quickly.
I guess I need to clarify that I am actually looking for a casting date previous to L-20-6.
Thank you for the reply. seeing the 3903352 casting number adds another cast number to the list of possibilities.
My Trucks:
Old 01-08-2015, 07:58 PM   #23
Dustytrix
ok he has it listed for sale on facebook, 67-72 chevy parts for sale. John Dyess.
Old 01-09-2015, 12:20 PM   #24
67 cst swb
67 cst swb's Avatar
It appears that I will need a block with a build date previous to L-19-6 and with a casting number of 3892657
After doing alot of reading on the Camaro and Corvette forums/websites, it appears that all Flint, Mich (denoted by the V) were 3892657 block numbers.
So a 3903352 will not be "correct".
So...
I will want to find a 3892657 block with a cast date of anywhere from L-01-6 to L-19-6.
My Trucks:
Old 01-09-2015, 12:28 PM   #25
jmader
jmader's Avatar
Would this one work?
http://www.ebay.com/itm/3892657-C-10...a9b22c&vxp=mtr
1967 Chevy SWB K10
Build thread-
