Old 11-06-2016, 09:47 AM   #1
Andy4639
Old member
Andy4639's Avatar
Thumbs up $155.00 Radiator
I bought another one! This one goes in the 67 ramp truck.I bought the same one a couple of years ago for my 71 and it's great no problems at all.
The price is right too!
http://www.ebay.com/itm/3-Rows-alumi...3D121400212717
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 11-06-2016, 10:09 AM   #2
dmjlambert
dmjlambert's Avatar
Re: $155.00 Radiator
Could you please show pics of how it mounted in the 71 and describe what is needed to mount it? Did you use new rubber pads intended for a four-row original radiator?
Old 11-06-2016, 10:23 AM   #3
Andy4639
Old member
Andy4639's Avatar
Talking Re: $155.00 Radiator
My 71 isn't stock by any means. I used a black foam in the bottom of it that sits in the support tray. I doubled up the foam to be higher than the support. It sits on the foam and on top I have a cover made to hold it in place.
The ramp truck will be more stock. I'll have to see how it fits but for the price and the cooling this one does in my 71 it will be worth it.
Old 11-06-2016, 12:04 PM   #4
TwoFiftyShifter
I think I paid similar for the eBay ec369. 2 row. I like it but it seems pretty thin.
1982 K10 SWB
1987 V20 - Sold - Doh!
TwoFiftyShifter is offline   Reply With Quote
Old 11-06-2016, 12:42 PM   #5
crakarjax
crakarjax's Avatar
How much lighter is this than a stock radiator? I'd think that most of the weight would be in the water contained right, so for weight savings you'd want to go with as little capacity as possible without overheating?
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 11-06-2016, 05:18 PM   #6
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: $155.00 Radiator
The three row is as thick as my old 4 row was. Much lighter though. I don't know about water amount but my 6.0 LS stay @179* all the time even in 90* and above temp outside.
Old 11-06-2016, 05:42 PM   #7
truckster
truckster's Avatar
No disrespect intended, but you're talking about a truck that even in its lightest version weighs 3500 pounds. Going with a smaller radiator to reduce the amount of coolant doesn't seem like it would make a whole lot of difference. Maybe if you're stripping it down to make the ultimate autocross truck...
Most people use aluminum radiators for superior cooling rather than for weight savings.
truckster is offline   Reply With Quote
Old 11-07-2016, 05:34 PM   #8
crakarjax
crakarjax's Avatar
Yep, but more important than overall weight is weight distribution. And at that end of the truck, several pounds can have a pretty large impact.
Old 11-07-2016, 06:17 PM   #9
In The Ten Ring
Oh wow, I wish I had known about that before I bought my last radiator. Is it really made in USA for that price?
That looks good and I hope it works well for you. Thanks for posting the link on it.
In The Ten Ring is offline   Reply With Quote
Old 11-07-2016, 07:22 PM   #10
Andy4639
Old member
Andy4639's Avatar
I don't think they are made here but it has been a good one in my 71 for almost 3 years now.
Old 11-08-2016, 11:59 AM   #11
crakarjax
crakarjax's Avatar
So, do they make one around that price with the inlet on the pass. side?
Old 11-08-2016, 10:12 PM   #12
wpavlis
I am currently trying to decide what to do for a radiator. Let us know how this one works out.
wpavlis is offline   Reply With Quote
Old 11-12-2019, 06:17 PM   #13
Andy4639
Old member
Andy4639's Avatar
Sorry I never updated this link. I've had this radiator now for 3+ years and not one problem. My 71 C 10 has been in for over 7 years and it's fine to.
CHR racing radiator.
I order all of them for automatic transmissions so if later I want to add the automatic I can, are a oil cooler.
Old 11-14-2019, 03:46 PM   #14
MDPotter
MDPotter's Avatar
I have been browsing the CHR radiators on eBay as well. When scrolling down the page, eBay shows other listings which appear to be the same radiator (from GPI or usaclassic). My guess is that they're made in the same factory overseas and then resold through different vendors. I'm seriously considering buying the usaclassic for $188 which comes with fans. Even if the fans are crap, I can use the radiator and shroud.
Do you happen to know the thread size and pitch on the trans cooler inlet/outlet and heater return?
Here is the usaclassic listing: https://www.ebay.com/itm/3Row-Alumin....c101112.m1982
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632
1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047
1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184
1978 Chevy Scottsdale K20
1993 Chevy C1500 - 5.3/T56 swapped
2008 Silverado Duramax
MDPotter is offline   Reply With Quote
Old 11-14-2019, 06:57 PM   #15
Andy4639
Old member
Andy4639's Avatar
No I do not.
I think your right because these last 2 radiator's showed up in GPI boxes.
I have no complaints on them so far.
Old 11-14-2019, 07:06 PM   #16
MDPotter
MDPotter's Avatar
I'm going to gamble and guess that they're 5/16" inverted flare to match factory. I'm most likely going to pull the trigger on that radiator. I'll give it a chance for $188 delivered. Do you mind letting me know the thickness of the tanks? I don't know if my stock radiator saddles will work or if they'll have to be stretched.
Old 11-14-2019, 07:25 PM   #17
Andy4639
Old member
Andy4639's Avatar
The pictures above are of my ramp truck with stock fittings in the stock holes. The ramp truck is a 4 speed but I went ahead and ordered the raidator for auto just in case in the future I want to go that way. Are maybe put a oil cooler in it.
I went out and grabbed some measurements for you. Hope they help. Yes the transmission fittings look to be 5/16" standard.
Old 01-30-2020, 11:05 PM   #18
68 P.O.S.
Been eying this thread for awhile. Andy, your review of the rad inspired me to go ahead and pick one up. Should be here end of next week ��
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 01-30-2020, 11:22 PM   #19
Andy4639
Old member
Andy4639's Avatar
I have one in all of my vehicles and not one problem with any of them.
71 c 10, 67 Ramp truck, 68 Step, 64 SS Impala and 56 Bel Air all have them.
I couldn't ask for a better radiator.
Old 01-31-2020, 10:28 AM   #20
MDPotter
MDPotter's Avatar
I'm still happy with mine! No leaks, looks great! The fans are cheap, so we'll see how long those last but I didn't have high expectations for them anyway. They're only about $20 each on Amazon.
Old 01-31-2020, 12:24 PM   #21
Andy4639
Old member
Andy4639's Avatar
Yea I didn't buy any of the fans, I don't think anyway. Come to think of it I think maybe I did for the 56 when I ordered it.
Old 01-31-2020, 12:54 PM   #22
maverickmk
maverickmk's Avatar
I may have to get one of these as well.
Die with memories, not dreams.
Not to brag, but I don't need alcohol to make really bad decisions.
1969 GMC Short Step Side
maverickmk is offline   Reply With Quote
Old 02-03-2020, 01:07 AM   #23
lux
Does it have a heater return inlet? If so what size. Thanks
lux is offline   Reply With Quote
Old 02-03-2020, 09:55 AM   #24
Andy4639
Old member
Andy4639's Avatar
I've never used the radiator heater connection on them. I always run it to the intake. I have no idea what size it is. All I've ever done is make sure it's tight.
Old 02-01-2020, 11:04 PM   #25
Knight72
I snagged one last night with fans because of this thread. Pretty far out from being ready to install, but I'll have it when I get there.
72 C10 lwb fleetside aka Big Rhonda.
Still plugging away.
Build thread:
http://67-72chevytrucks.com/vboard/s...42#post8247142
Knight72 is offline   Reply With Quote
