11-11-2016, 07:52 PM | #1 |
Door handle slow
Is it normal for the inside door handle when lifted to fall slowly back down? Or should it snap back down once lifted up?
I lift mine up and it slowly if not doesnt fall all the way down? Any ideas? Is the latch shot? |
11-11-2016, 08:34 PM | #2 |
Re: Door handle slow
min e snaps back id try taking the door panel off and wd40 the heck out of everything . my door locks were froze solid it took a couple days but theyre working fine now
11-11-2016, 08:44 PM | #3 |
Do these things go bad? I will pull it a part and take a look.
11-11-2016, 09:11 PM | #4 | |
The Older Generation
Return spring is broken on the remote mechanism. I haven't found a way to repair them.... I would try the lube first like the others have suggested though. Much easier if it works... LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 11-11-2016 at 09:57 PM. |
11-11-2016, 09:25 PM | #5 |
I used the Special WD-40 , dry lube rust inhibitor, to lube the door hardware on mine.
Before I did, rolling the driver's side window was a two-handed tasks, now it works fine. |
11-11-2016, 11:11 PM | #6 |
I am rebuilding my doors right now. Both of my springs are broken. The new door handle mechanisms are $19.00 each.
http://67-72chevytrucks.com/vboard/s...d.php?t=698292 |
11-11-2016, 11:36 PM | #7 |
Is it the door latch that is the issue? That 50$ or so.
Where is the spring that is broken so I can look on mine |
11-11-2016, 11:40 PM | #8 |
Or is it the door control? That i see is 14.95. Is it the spring in this mechanism?
11-12-2016, 01:08 PM | #9 |
I'm having the same problem.. I always have to remind people to push the handle back down
11-12-2016, 01:10 PM | #10 | |
Hadn't seen it called "Remote mechanism" - a.k.a. door latch control. The spring on my LH control was broken and same symptoms.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
11-16-2016, 11:23 AM | #11 |
Thanks everyone. The control was shot. I ordered a new one and it snaps back quite well. No lubricant was gonna fix the old one.
11-16-2016, 12:06 PM | #12 |
11-16-2016, 08:28 PM | #13 |
Yes. I already had to doors torn apart as they were getting painted. So putting it back in was no biggie.
