11-13-2016, 11:10 AM | #1 |
Fuel system help
Hey guys,
Ok I've been doing a bunch of searching and I can't seem to find a good way to go about this. Maybe some one on here has done this correctly. I picked up a 99 vortec engine for my 67 c20. There isn't provisions for a mechanical pump as I'm sure you are aware. I have a Holley style rotary vane pump and a Mallory return regulator. This is a carburetor setup. My problem is trying to figure out a efficient way to run a return line. I found a replacement behind the seat tank through LMC that has a 1/4 bung somewhere on the tank. I tried to ask them the location but they had no clue. My concerns with this tank are: #1 is it too hard on a frame mounted Holley rotary vane style pump to use the stock style pick up #2 is a 1/4 inch bung too restrictive for a pump that flows 105 GPH at 14 psi? I really like the idea of the behind the seat tank but if it's just not possible I'm open to suggestion that don't involve $400 aluminum tank at the moment. |
11-13-2016, 12:02 PM | #2 |
Re: Fuel system help
Have a 350 Vortec also, I'm assuming the 1/4" bung is NPT, if so it will work fine as a return (approx. 3/8"). As for the location of the pump, I have a carter mounted on the frame rail close to the same location of the original line. I would have loved to run a stock mechanical pump but the block wasn't drilled & was already assembled. Many machine shops have a jig do drill the fuel pump push hole so you can run a stock style pump. I would have done this if my block was disassembled.
11-13-2016, 05:54 PM | #3 |
Thanks for the photo. What tank are you using and are you running a return? It is a 1/4" NPT bung.
If I run a 3/8 line for a return to the tank where there is a 1/4" bung wouldn't this bottle neck and cause some restriction? The instructions for the pump say to run a return line same size as the feed or bigger. Has anybody had any success or problems with a smaller return? And is anybody using the LMC 32-5923 tank? |
11-13-2016, 10:05 PM | #4 |
I'm not running a return, it's a 5 psi pump. A 3/8" return line will work fine. Most carburetors like 5-7 psi. Not a bad idea to run a regulator, I've had electric carters fail & push too much pressure.
11-15-2016, 12:31 AM | #5 |
Thanks B.W.? How long do your carter pumps last? Your set up looks great by the way.
Has anybody on here hooked up a return line to their behind the seat tank? Pictures would be really helpful! |
11-15-2016, 11:31 AM | #6 | |
Posted via Mobile Device |
11-15-2016, 03:49 PM | #7 |
Thanks for the compliment. I've run carters on may different rigs, both vehicles & boats, I thing they are great pumps for stock applications. I can't remember any of them failing to pump. The last one I had an issue with was on a 500 caddy with a q-jet. It kept sinking the float from too much fuel pressure.
