Old 11-16-2016, 02:15 AM   #1
mosel70
Heavy vibration when turning left
1970 Chevy C10, stepside, 2wd, 396ci. I had manual steering and installed a power steering kit from Tuckers (pump, gearbox, lines). After installing, it had vibrations when turning. Thought it was a bad new (remanufactured) pump so I returned it and installed replacement. Now good steering straight and when turning right, but it shakes/shimmies bad when turning left, especially at lower speeds like in a parking lot. Good fluid, no air. No play in steering. When turning while on jacks with engine on and off, it seems to turn fine both directions.
mosel70 is offline   Reply With Quote
Old 11-16-2016, 12:09 PM   #2
Boog
laying low
Boog's Avatar
Re: Heavy vibration when turning left
Do you have dropped spindles and 8" rims on front? If so get under there and look at the lower control arm around the ball joint area and wheel lip for contact. It can feel like that. Mine did.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 11-16-2016, 04:26 PM   #3
mosel70
Old 11-16-2016, 04:28 PM   #4
mosel70
I'll look. I have 2 1/2" drop spindles and 12" rims. Thanks.
Old 11-17-2016, 03:31 AM   #5
mosel70
correction, 15" rims
Old 01-18-2017, 02:41 AM   #6
mosel70
Found out my passenger side header was contacting the frame. When I removed it, also found out it was the wrong header for the truck. Thanks to the guy I bought the truck from last summer, huh?! lol
Old 01-18-2017, 03:22 AM   #7
HO455
HO455's Avatar
Angry Re: Heavy vibration when turning left
At least they didn't take a torch to the frame to make clearance like my PO did.
RIP Bob Parks.
Old 01-19-2017, 11:37 AM   #8
snipescastle2
snipescastle2's Avatar
Talking Re: Heavy vibration when turning left
I installed 2 1/2" drop spindles on mine, and the lower control arms (where the ball joint is pressed in) hit the wheels (stock 15" X 8" rally's) so, I had to clearance the area it was hitting the rims took off as little material off the control arm as possible, so it didn't weaken the ball joint area. Probably could have fixed the issue running 15" x 6" rims, but I wanted the wider rims......
Glad it is as simple as a header fit issue, but those headers aren't cheap, even the inexpensive ones cost a bundle. glad you got it sorted out.
Ben
"Persistence is the twin sister of Excellence.one is a matter of quality,the other, a matter of time"
“Serious Black” my 1971 Short Bed Fleetside Sold to
an outstanding man in Lees Summit,Mo. “Gone, but by no means,Forgotten”
snipescastle2 is offline   Reply With Quote
Old 02-23-2017, 02:07 AM   #9
mosel70
I finally found out what I did. I installed new valve covers and the drivers side cover was making contact with the firewall. I dented in the corner of the valve cover and and am completely vibration free, drives like a dream.
