![]() Join Date: Jan 2012
WTB - 1960 GMC rating plate
Mine is missing.
It's this one, but the one for the 1960 will be slightly different (engine type)... Thanks! -Scott |
Re: WTB - 1960 GMC rating plate
I'll check if I have one. I know some of the 1960 GMC's had the VIN number on that plate.. Is yours a 1/2 ton truck or ?
![]() Join Date: Jun 2007
if your VIN is not stamped in the rating plate, your truck is a 61 up instead of a 60 regardless of what the title says. Many trucks were titled in the year sold rather than the year model they actually were - I have never seen a true 1960 GMC that did not have a single tag for VIN and rating.
My Projects and Toys - All 100% Stock 1972 CST "Highlander" Blazer - 350 auto, PS, PB, A/C, Tilt, Tach, AM/FM & Positraction 1966 Chevy SWB Fleetside BBW Custom Cab, #'s matching 327 V8 & Powerglide, factory deluxe heat, PS, PB, Tinted Glass, sway bar 1961 Chevy SWB Fleetside BBW Custom Cab #'s matching 283 V8 & Powerglide w/ uber-rare Cool-Pack A/C, factory PB, deluxe heat, Clock 1961 GMC K1000 4x4 SWB w/ BBW, Custom Cab and numbers matching 305D V6 engine & 4 spd 1960 GMC SWB Fleetside BBW Custom Cab #'s matching 305A V6 & Hydramatic, factory PB, Clock, Tach, Compass, Hood Jet 1959 Chevy SWB Fleetside BBW Custom Cab w/ rare stainless bed trim, #'s matching 283 V8 & Hydramatic, Deluxe Heat, radio, spotlight 1958 Chevy Cameo #'s matching 283 V8 & Hydramatic, radio, window washers, Factory PB 1958 GMC BBW SWB Fleetside Custom Cab, #'s matching 336 V8 Hydramatic, Factory PS, PB, Clock, RSD, Deluxe Heat & Hood Jet 1957 GMC Suburban Pickup (GMC's Cameo) #'s matching 347 V8 Hydramatic, uber-rare vacuum ashtray, Factory PS, PB, Clock, RSD, Hood Jet 1956 Chevy 3800 1 ton w/ rare 9 ft stepside bed, factory 265 V8 w/ Hydramatic, factory PB, Custom Cab, deluxe heat, spotlight and hood jet. |
hey steve what would be the most "correct" rating plate in this case then? so i know what to look for
Lets see if the 6066 crowd agrees or argues with me on my assertion that 1960 was the last year of the VIN being on the kick panel tag - not sure if those guys have weighed in yet. If they agree, then the kick panel type all-in-one tag is what your 1960 needs.
#7 | |
He basically told me that my truck was 'fishy' and could be a clone and that I was trying to pull a fast one on the sheriff's office while trying to get a bonded title. Ugh. Thankfully other, more seasoned members set him straight. Oh, I see you're already posting over there too. Nevermind...you know what's going on over there too ;-) Last edited by AngryPirate; 11-28-2016 at 02:21 AM. Reason: realized gmcnut was already informed. |
#8 | |
Pirate, I forgot - maybe you are the one saying your truck didn't have a tag at all - forgot that. So to be a 60 you need a kick panel 1960 tag w/ 1000 series VIN and if you are wanting a 61-62 identity tag, that is on the door frame and is a skinny tag that rivets to the two holes you found there
#10 | |
![]() Join Date: Mar 2013
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
#11 | |
I have a 305A engine in my truck as well, which I believe is the 305 v6 that was in all 1960 GMC 1000 series. I believe it will look something like this, but with 305A and slightly different HP ratings on it. ![]() This rating plate may not exist without a serial # on it though. I really don't know. I appreciate you looking though. ;-) |
well in this case if his vin is on the door jamb he won't want a kick panel tag with a vin on it.. do you know the gvw for a shortbed off the top of your head?
I found a couple so far, but both are 305E. I'll keep looking.
Interesting though, I checked 4 different 60-61 trucks and they didn't have any kick panel tags - just the holes. So yours may not be missing - it might not have come with one, especially if all the data info is already on the pillar. |
![]() ![]() Join Date: Apr 2012
Steve , out of four 1960-1961 trucks I have , two 60s two 61s , three have the kick panel vin and one has the A pillar VIN. I have three 1962s , all have the A pillar VIN like the one 1961 does. NONE of the A pillar 1961 1962 VIN trucks have kick panel GVW tags . 1963 GMC has the normal GVW tag on the kick panel and then they changed the VIN tag to a spot welded stainless tag like Chevys. Theres nothing wrong with your truck Angrypirot , but there is a real lack of understanding over at the GMC site ! WOW!
I have a similar GMC VIN screw up. Its a 1966 GMC 4x4 panel with very low miles. Heres the problem, the VIN tag style is the same as a 1964-1965 tag, the vin tag style changed in 1966 . Everything on this truck is dated for a 1964 production model year. The tag was never removed , but like Steve is saying , GMC titled the truck the year the truck was sold. This truck of mine has 6000 original miles and was built for Civil Defense , that is most likely why it was titled so late as a 66. The "geniuses" over at the GMC sites first response is the tag and title are not to the truck ! What ? I buy it from the original owner township that bought it NEW in 1966 and the VIN got changed ? Theres a couple of egotistical idiot know it all's over there that are afraid to LEARN anything new and you cant tell them theyre wrong when they are . I used to go there quite often , not anymore. THE OLD 6066GMC site has some great info posted though.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
#15 | |
That information site attached to the 6066GMC site is pretty great, but one of the "know it all's" over there didn't want to admit he was wrong, so he said the information site was incorrect and he was right. UNREAL. Oh well....it appears my 60 GMC may actually be a 61. At least some good information was arrived at on both sites forums around the ID plates. |
#16 |
I read through that post on the other site front to back. My question is , what made you think its a 1960 vs a 1961 ? When researching my 1966, that's actually a 1964 build , I checked all the dates on the engine , intake , heads block etc , were all dated for a 1964 production truck. Im using the dates like anyone would restoring a car. It might help you figure it out ?
#17 | |
#18 |
![]() Join Date: Feb 2011
My 61's data plate location. I'll have to look at my date stamped parts to see what I may really have .
MusicMan70 1961 GMC Suburban |
