Old 11-25-2016, 04:02 PM   #1
61ShortboxDave
61 Apache Short Box C Notch
Has anyone C notched there 61 frame? Would you have photos or any other info to share? This is another kit type item I see readily available for 63-66 frames but not the 60-62. I'm fine with fabricating what I need to but I'm always open to seeing what others have done and listening to suggestions.
Thanks for any info, Dave
61ShortboxDave is offline   Reply With Quote
Old 11-25-2016, 06:15 PM   #2
LVPhotos
LVPhotos's Avatar
Re: 61 Apache Short Box C Notch
I did a pipe notch. 5" x 3/16" cut for 2" notch. Porterbuilt has the big notches if you plan on dropping more and cutting bed. I really don't need the notches because my shocks hold me up from dragging mufflers. Plus any lower the pumpkin pokes through. Tire pic is down inside notch.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 11-25-2016, 09:18 PM   #3
canadian_diesel1964
Man that looks sweet
canadian_diesel1964 is offline   Reply With Quote
Old 11-26-2016, 02:51 AM   #4
Jcox68rt
I did a simple notch also on another truck of mine. I made sure to box the frame and reinforce the outside of the frame as well...can't be too strong in my book.
Jcox68rt is offline   Reply With Quote
Old 11-26-2016, 10:52 AM   #5
LVPhotos
LVPhotos's Avatar
The 60-62 X frame is already boxed in that area from factory.
Old 11-28-2016, 09:18 AM   #6
61ShortboxDave
Thanks very much for the info and photos!
