Installing Windshield & Chrome
About to the point of needing to get my rear and front window put back in my truck. I have the rubber and glass and the chrome. I will get safelite or someone to put the windshield back in. My question is, does the chrome need to be put on the windshield before the windshield is put back in the truck or does it matter? Thanks.
Re: Installing Windshield & Chrome
Chrome (stainless steel, technically) gets installed into the rubber seal AFTER the seal is on the windshield but BEFORE the windshield is installed. So the glass, rubber, and trim is installed as a pre-assembled unit.
It CANNOT be added after, if that's what you were wondering.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
#3 | |
Dont let em talk you out of the trim when they aren"t able to install the unit. Find an old timer if you arent comfortable doing it yourself.
Once you get it all on the glass let it sit for a day or two to relax then you have less chance of the chrome lifting out during installation it's really no big deal just keep an eye on the top corners of the windshield they seem to be the only spot to come out in my experience
makin sure you have the right rubber for the right trim is essential
Which rubber do I need if I have the Chrome(stainless steel) trim? I purchased the deluxe cab rubber at Truckandcarshop. The only choices were deluxe cab and standard cab. Was the deluxe correct? Thanks.
I've done the OEM trim using "Precision" rubber. I've found it's the best out there the hard way.
1972 Highlander PAC B 400BB-SOLD 1974 K5 Blazer-6.0 swap 1974 C20 Long Bed 454 1977 GMC HeavyHalf several adopted orphans |
Carpe manana
![]() ![]() Join Date: Dec 2010
If you are using aftermarket trim it likely will not fit. OEM trim is an easy install. See my thread here: http://67-72chevytrucks.com/vboard/s...d.php?t=484773
Good luck.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
