Old 12-02-2016, 11:26 AM   #1
joewell80
Torque Thrust 2, 18 or 20's
I'm thinking about pulling the trigger this winter on new wheels. I cant decide if I should go with 18's or 20's. I don't want the wheels to look to big on the truck. Does anyone have pictures of there truck on TT2 18's?
Thanks.
joewell80 is offline   Reply With Quote
Old 12-02-2016, 11:45 AM   #2
hewittca
hewittca's Avatar
Re: Torque Thrust 2, 18 or 20's
There are quite a few threads already on TT2s with good examples of what you are looking for. This thread has a good example of a truck running 18/20 TT2 to give you a good comparison of the two sizes, and this thread just has a bunch of examples of trucks on torque thrusts in a range of sizes. But to answer your question, here's a nice photo of beaterku's truck on 18x9, 5" bs, and 265/50r18s. It depends on what stance you have, but I do think anything up to 20" looks proportionately normal on these trucks. Once you get to 22" and up they start to look big.
Builds: Green Gus the 68 C10 | Bluey the 72 1500 | Lowly the 70 C10
Instagram: @dr.hewitt
C10 Concept/Development Photos: Master Thread
hewittca is offline   Reply With Quote
Old 12-02-2016, 01:39 PM   #3
Mike C
Mike C's Avatar
18's. I think anything up to 18 looks good with enough sidewall. 20's are just too much IMO.
I have 17's on my truck and would probably go 18's if I had to do it again just for tire assortment and availability.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 12-02-2016, 01:40 PM   #4
FRCvette
That truck is a beauty.
There's something women like about a pick-up man
1967 c10 swb Stepside
2004 SSR
2013 Silverado swb
FRCvette is offline   Reply With Quote
Old 12-02-2016, 02:17 PM   #5
David67
David67's Avatar
These are 17" on a 4/6 drop. If I were to do it again, I might go 18s. I am bagging so I am going with 20" Salt Flats. I think static dropped fleetsides can pull off 20s much better than static dropped stepsides.
1967 C10
Fightin' Texas Aggie Class of 2015
IG: david_r67
David67 is offline   Reply With Quote
Old 12-02-2016, 03:55 PM   #6
67 chevelle
67 chevelle's Avatar
Our trucks have huge wheel wells , larger than stock looks good on them . I like big rims , and decent to big tires [hate rubber band tires ]
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 09-04-2017, 10:32 PM   #7
jgmc
What are your tire sizes
jgmc is offline   Reply With Quote
Old 09-05-2017, 12:47 PM   #8
beaterku
beaterku's Avatar
I saw my name come up a few times in this thread so I thought I'd put up a more current pictures I've actually been kicking around the idea of switching up my wheels. I am liking the looks of the US Mag Rambler in 18x9.5 all around. I'm going to wait to see what it looks like with this Ridetech steetgrip kit and check for clearances.
-Nick
beaterku is offline   Reply With Quote
Old 12-02-2016, 10:25 PM   #9
You fill in fender wells with tires, an old school wheel design looks best when the diameter is kept only a little larger than normal (if you must go larger at all)
Old 12-02-2016, 11:21 PM   #10
David67
David67's Avatar
Not sure I entirely agree... The lower you go, the bigger you can go IMO. Bennett68C10's awesome truck in progress. \/
1967 C10
IG: david_r67
Old 12-03-2016, 12:27 AM   #11
Robznob11
Robznob11's Avatar
Consider your tire width as well...if you like em wide go with 18s. I think i will roll 18s when the time is right. You get a good look but the performance and ride quality are much better with a little meaty side wall.....also large wheels are very heavy and hard on front end parts and all.
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 12-03-2016, 10:44 AM   #12
joewell80
Thanks for the info. The truck is on bags right now, so that should help if I go with bigger rims. No matter if I decide 18 or 20's, I want the same size on all four corners so I can rotate.
Old 12-03-2016, 11:14 AM   #13
ss454conv
As others have said, it all depends on your taste and how you intend to use your truck. For myself, I wanted to be able to use my truck as a truck, be able to rotate, not have a harsh ride and still look cool. I searched this site and others for the right look. As soon as I ran across beaterku's truck, I knew that was the look I was going for. I purchased the exact same wheel and tire package for mine and love it. Still need to install a 2/4 drop but I will get to that pretty soon.
I also agree with the idea that larger wheels require a lower ride height.
18=2/4
20=5/7
22=5/7 or lower
Ultimately it has to be what looks great to you.
ss454conv is offline   Reply With Quote
Old 12-03-2016, 02:25 PM   #14
Bennett68C10
Bennett68C10's Avatar
Thanks for the shout out brother
I'm a 20" or larger wheel guy but I also like my trucks lowered/bagged so it looks proportioned. 18's look really good too with a nice size tire.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 12-03-2016, 07:42 PM   #15
jessemthompson
I would go with 20s, there are more sizes available than 18s and they are usually less expensive.
jessemthompson is offline   Reply With Quote
Old 12-03-2016, 07:45 PM   #16
Robznob11
Robznob11's Avatar
UM that's not what I found during my research....
LED TAILS
Old 12-18-2016, 06:31 PM   #17
rowdy350
Just got these 18x8 and 18x9.5 on my 71. Along with new RideTech control arms. Front ride height needs to come up some more and the rear needs to come down a little more.
rowdy350 is offline   Reply With Quote
Old 12-18-2016, 11:45 PM   #18
kxmotox247
kxmotox247's Avatar
18x8's and 20x10's.
kxmotox247 is offline   Reply With Quote
Old 12-18-2016, 11:48 PM   #19
kxmotox247
kxmotox247's Avatar
245/40/18 and 295/45/20
Old 12-19-2016, 09:03 AM   #20
srea76
srea76's Avatar
Whats the biggest wheel to use on a stock 71? My truck has 15x10s on it now and I knid of like the look, but I want to change wheels.
1972 Custom Deluxe LT1 Gen V Swap "Green Lantern"
1984 Silverado
Red Baron-72 c10 Project
srea76 is offline   Reply With Quote
