Shifting linkage help
I have a 71 Chevy c10 with a 350, and th350 trans. When I go full throttle in drive, the forks coming off the transmission where it shifts, the linkage pops off there every time. When I manual shift it, going from 1st to 2nd it seems like it's in a bind and it requires a lot of force on the gearshift to shift into 2nd. Is there anything I can do so it will not fall off anymore?? I just finished replacing my trans mount, and it didn't help at all
Posted via Mobile Device |
Re: Shifting linkage help
What about drives side engine mount? Certainly sounds like things are moving around under the hood.
I looked at them, they don't look too bad. I figured if the motor was moving around enough to pop it out, then the fan should be hitting the plastic molding somewhere, but it isn't.
![]() Join Date: May 2015
Is it coming off on the transmission or the linkage on the steering column? Mine kept falling off by the steering column because the grommets were loose/broken.
The Older Generation
I would guess front motor mounts are broken.... Does your linkage look like this? Note the spring, If it isn't there it could cause your problem.... LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 12-05-2016 at 11:37 PM. |
